It is currently Mon Jan 20, 2020 6:19 pm
PostPosted: Fri Jun 14, 2019 7:25 am
Hey,
I'm using CODESYS V3.5 SP14.
I created a WebVisu with some visualizations and downloaded it on the CODESYS Control Win V3.
When I try to access the homepage after starting the soft PLC I get the error message "cannot open document".
I already checked if the IP is correct and the name of the .htm file in the WebVisu settings.
I tryed to change the port (maybe there is another webserver running on the computer) in the CODESYSControl.cfg with
[CmpWebServer]
WebServerPortNr=9090
The PLC still starts the webserver with the default port.
Does anyone have an idea what the problem here is and how I can change the port?
Thank you for your help!
Fabian
PostPosted: Fri Jun 14, 2019 8:48 am
Should work.. which plc is it?
PostPosted: Fri Jun 14, 2019 9:03 am
It's the CODESYS Control Win V3 - x64 Version 3.5.14.0.
Any Idea why the port doesn't change after editing the .cfg file?
PostPosted: Fri Jun 14, 2019 6:11 pm
C:\ProgramData\Codesys....
In this location the Configfile is stored.
PostPosted: Mon Jun 17, 2019 7:09 am
Thank you very much!
I changed the .cfg file in the wrong path (C:\ProgramFiles\Codesys not ProgramData).
Now it's working :)
cron
