It is currently Sat Dec 07, 2019 3:23 pm
PostPosted: Mon Apr 29, 2019 7:58 am
Hello Community,
I try to check if there is a MultiCore license available on the runtime.
This function works well, when I check the single core license or other single licenses, but not for multi core.
hHandleCmpCodeMeter:= CMPCODEMETER.CodeMOpen(udiFirmCode,udiProductCode,udiFeatureMap,rtsResult);
If I check for a multi-core license, the function returns an CmpError Code "40", which is described as a "Device_Error".
Can anyone help me with this?
Thank you in advance,
BR KevinR
Building & Process Automation with HVAC Library for CODESYS© - www.hvac-automation.com
PostPosted: Mon Apr 29, 2019 5:10 pm
use:
Update:
Could check if 16#20000000 ( you need to give this feature map in hex) then it will work.
Handle:= CMPCODEMETER.CodeMOpen(5000304,8787,16#20000000,Result);
PostPosted: Thu May 02, 2019 2:30 pm
I verified it and it works well.
Thank you so much, Edwin
Kevin
