It is currently Tue Jan 28, 2020 4:42 am
PostPosted: Thu Apr 18, 2019 4:15 pm
Hi everyone,
I'm trying to get some info from a Raymarine network into a Wago PLC. I believe I have the PGN pulled out of the CAN ID correctly but now what? Does anybody have any info how exactly those fields are built and multiple messages reassembled?
I tried first on a car OBD port but that is a whole dogs breakfast if you don't know what to expect.
I'm using Wago E!Cockpit so I have to receive the 29 bit frames and deal with them. A library would be great.
PostPosted: Fri May 24, 2019 7:24 pm
If I'm not mistaken, the NMEA2000 standard is closed and costs several grands, and as far as I know theres no such thing as NMEA2000 library. Closest thing is: https://github.com/canboat/canboat, where they have done some reverse engineering.
I think your best bet would be to use a NMEA2000-NMEA0183 converter where the latter i pure ASCII.
PostPosted: Wed Jul 10, 2019 11:45 am
Thanks, CANBoat had all I needed to adapt. A few things are tricky though like injecting messages to control autopilot. So much traffic it is hard to find the right messages to spoof.
Sent from my SM-G975F using Tapatalk
PostPosted: Fri Aug 23, 2019 9:46 pm
I also believe you can set up a J1939 network in CoDeSys and add custom PGNs which you can point to the NMEA2k you want. Raymarine should have some sort of document with the common PGNs.
