It is currently Thu Feb 27, 2020 6:10 pm
PostPosted: Mon Mar 11, 2019 5:56 pm
When I want to execute a test in CodeSys TestManager, I need to click Test Repositories -> Edit Test Repositories -> Add -> select the .xml and give it a name.
Is it possible to automate this so I don't need to access the build node, open CodeSys and do the above steps?
Thanks in advance for the help!
PostPosted: Fri Mar 15, 2019 3:52 pm
For those interested, I fixed this by writing a python script that collects the relevant data from the CodeSys XML and then writes it in a new XML in the JUNIT format. You can then get nice statistics in Jenkins when you post the xml to JUNIT (also install Jenkins Junit add-on).
PostPosted: Thu Jul 11, 2019 9:10 pm
Would you kindly share this script? I am very interested in it.
Thank you in advance.
CfUnit, free and open-source IEC61131-3 unit-testing framework
My profile
PostPosted: Wed Aug 07, 2019 8:39 pm
I am also very interested in how you went about converting the XML file into JUNIT format. Would you mind sharing?
PostPosted: Tue Aug 13, 2019 6:00 pm
I created a script to do the conversion to Junit XML here
