It is currently Wed Jan 22, 2020 8:38 pm
PostPosted: Tue Feb 26, 2019 9:40 am
Hello,`
I am trying to implement MC_MoveVelocity and MC_GearIn on two axes. Both the Master and the Slave axes are in Cyclic Synchronous Position operation mode.
Question 1: Is it possible to change the velocity of the Master axis (via MC_MoveVelocity) and the gearing ratio of the Slave axis (via MC_GearIn) simultaneously?
It looks to me like either the Master axis has to be InVelocity in order for the MC_GearIn instance to perform a proper gearing or the MC_GearIn has to be InGear in order for the Slave axis to properly follow changes of velocity on the Master axis.
Question 2: Does MC_GearIn subscribe on Actual Position or Set Position?
If executing MC_MoveVelocity and MC_GearIn simultaneously does not perform the expected motion, I could execute MC_MoveVelocity on both axes after the gearing ratio to be performed and take care of aborting the one MC_MoveVelocity if the other MC_MoveVelocity is aborted or throws an error.
Thank you very much in advance.
