It is currently Fri Sep 20, 2019 7:07 pm
PostPosted: Mon Feb 11, 2019 5:26 pm
I have a little problem with property. (I use CODESYS V3.5 SP14)
I writted an objet FB1
FB1 Function block
ErrorFB1: Struct1;
I use MyFB1 :
VAR_GLOBAL
MyFB:FB1;
Struct1 is a structure, declared like this :
Struct1:
ErrorBit1:BOOL;
ErrorBit2:BOOL;
Error_Code:INT;
END_STRUCT
I can write 3 properties to get the value of each variable ErrorFB1.ErrorBit1, ErrorFB1.ErrorBit2, .... wtih properties like this :
Property Read1 : Bool;
GET
Read1:= ErrorFB1.ErrorBit1
It works well.
But I try to write only one property to get the entire structure ErrorFB1 :
Property ReadAll : ErrorFB1;
but It don't work.
I read somewhere, that I have to declare a REFERENCE, so I wrote :
Property ReadAll : REFERENCE TO ErrorFB1;
GET
ReadAll :=ErrorFB1;
In my programme I use :
Default1:=MyFB.ReadAll;
And I get an exception when I run the simulation mode.
I am a beginner in the use of OOP. I looked for examples but I founded only "simple" one.
I have certainly made a monstrous mistake somewhere, but I do not see it :oops:
Thank you in advance for any help. :D
PostPosted: Tue Feb 12, 2019 1:04 am
I found my error; :D
As the property is a REFERENCE, I have to write "REF=" instead of "=" in the GET acces :
GET
ReadAll REF=ErrorFB1; :oops:
Users browsing this forum: No registered users and 8 guests
