It is currently Wed Sep 18, 2019 1:00 pm
 Post subject: CANopen SDO_Write4
PostPosted: Tue Jan 29, 2019 9:25 am
Hi all,
i'm trying to send a sdo to a slave by using the following code... The SDO is transmitted correcly and also the slave received it correcly and answered with the acknoalge (60 xx xx xx xx xx xx xx) but the SDO_Write4.CONFIRM never rise up...
Do you have an idea about this strange behaviour?
IF xEnable = FALSE THEN
xLastEnable := TRUE;
xEnable := TRUE;
wsdo_index := 16#1400; // SDO write 0x1400 SUB index 1 à 7F 02 00 80 (Receive PDO disabled
wsdo_subindex := 16#0001;
SDOWrite4.DATA[1] := 16#7F;
SDOWrite4.DATA[2] := 16#02;
SDOWrite4.DATA[3] := 16#00;
SDOWrite4.DATA[4] := 16#80;
SDOWrite4(
NETWORK:= CANbus.NetId + 1, //CODESYS NetId starts by 0 (the number entered into the CANbus configurator); CiA405 NETWORK by 1; That is the reason why we have to increment it here.
ENABLE:= xEnable,
TIMEOUT:= 50, //Timeout for SDO read in ms. Here: 0 ==> no timeout
//DEVICE:= CANopen_Device_1.NodeID, // NodeID of destination device
DEVICE:= 126, // NodeID of destination device
CHANNEL:= 1, //SDO channel which should be used. 0 means auto channeling ==> the next free channel will be used. It depends on the slave which settings are working here but 0 and channel 1 is always working.
INDEX:= wsdo_index, //object index which should be read
SUBINDEX:= wsdo_subindex //object sub index which should be read
ELSE
IF SDOWrite4.CONFIRM THEN
xEnable := FALSE;
SDOWrite4(Enable := xEnable);
ELSIF SDOWrite4.ERROR <> CiA405.CANOPEN_KERNEL_ERROR.CANOPEN_KERNEL_NO_ERROR THEN
//Error occured
xEnable := FALSE;
xLastEnable := xEnable;
 Post subject: Re: CANopen SDO_Write4
PostPosted: Wed Jan 30, 2019 3:55 pm
Hi Stefno86!
I think, you should call the function block "SDOWRITE4" cyclical, i.e. outside of the IF ... ENDIF query. If I take your code, the easiest way is to move the call below the END_IF:
xEnable := TRUE;
ELSE
xEnable := FALSE;
// don't call here !!!! SDOWrite4(Enable := xEnable);
//Error occured
xEnable := FALSE;
SDOWrite4(
ENABLE:= xEnable,
Just try, and good luck!
Alfred
