It is currently Mon Feb 17, 2020 8:02 pm
PostPosted: Thu Jan 24, 2019 5:47 pm
I'm trying to read analog inputs on a Modbus RTU device.
The COM Port doesn't work.
I added the SysCom in CODESYSControl_User.cfg.
Any suggestion?
Best Regards
Straccio80
PostPosted: Fri Jan 25, 2019 9:17 am
Hi Straccio80,
did you try Com Port number 2 in codesys. Because Com port 1 is used for the rs232 console port.
Gesendet von meinem LYA-L29 mit Tapatalk
Building & Process Automation with HVAC Library for CODESYS© - www.hvac-automation.com
PostPosted: Fri Jan 25, 2019 9:41 am
Hi KevinR,
I Tried, it's the same.
Thank you for replying.
Best Regards
Straccio80
PostPosted: Thu Feb 07, 2019 10:25 am
i fixed the problem.
In CODESYSControl_User.cfg i setted
[SysCom]
Linux.Devicefile=/dev/ttyUSB
instead of
[SysCom]
Linux.Devicefile=/dev/ttyRS485
and it's working fine.
Best regards
Straccio80
