It is currently Sun Feb 23, 2020 5:41 pm
Post new topic  Reply to topic  [ 10 posts ]
 Post subject: Beckhoff EL6751
PostPosted: Sun Jan 20, 2019 8:54 am
I'm pulling my last remaining hairs over the CANOpen setup I inherited from a colleague ...
Searchin' the WWW I found this forum post https://forum.codesys.com/viewtopic.php?t=8932 however the "solved the problem message" is kind a blurry. Maybe because my knowledge of the German Language is mainly inspired by Jean Marie Pfaff "Ich habbe in Belgiën shon fiele penalties gestopft". :lol:
I have the same problem, cant get the configuration to work. All Can devices have the red triangle next to them CAN-ERR and RUN led's blink rapidly. (See screenshot)
Any input on the matter will be greatly appreciated.
Koen.
[edit] Forgot to mention ... when I scan the EtherCat master for devices I get this result ...
The EL6751 does not appear in the device list. Scanning the CAN master returns no devices.
 Post subject: Re: Beckhoff EL6751
PostPosted: Sun Jan 20, 2019 10:51 am
I would recommend to check the plc logger… and set CANOPEN_DEBUG as Compiler define
to get more information.
PostPosted: Sun Jan 20, 2019 11:50 am
Hi Edwin,
Where do I define CANOPEN_DEBUG?
Koen.
PostPosted: Sun Jan 20, 2019 5:52 pm
Hi Koen,
Application Properties (rightclick on application in the device tree)
here:
PostPosted: Sun Jan 20, 2019 5:58 pm
Hi Edwin,
Thanks I found it. I have lots of CANOPEN related defines in there.
CANOPEN_NO_MODULARDEVICES, CANOPEN_NO_NODEGUARDING, CANOPEN_NO_SYNCPDOS, CANOPEN_NO_SYNC, CANOPEN_NO_TIMEPRODUCING, CANOPEN_DEBUG
The log returns:
Hope you can make something of it.
Koen.
PostPosted: Sun Jan 20, 2019 6:03 pm
hm.. CANbus resitors or wiring ..?
PostPosted: Mon Jan 21, 2019 7:29 pm
Hi Edwin,
I have the CANOpen bus up and running now, the problem was a firmware version in the EDS files for the BK5120. I have the BA version and loaded EDS files for more recent version.
Moving the problem up I found xml description files for the KL modules but they do not get loaded in because "The import filters couldn't be found". Can you please point me in the right direction? I have KL1104 and KL2134 I/O.
KR
Koen.
PostPosted: Tue Jan 22, 2019 2:52 pm
I think there are no EDS files available for this... (maybe I'm wrong)
please ask the Beckhoff Support.
Another Option which I would prefer is to use BK1120 or 1150 - there you could get an MDP Version which would make it possibe to use
KBUS
PostPosted: Wed Jan 23, 2019 2:04 pm
Hi all,
I find this kind of strange ... BK5120 is a CANOpen K-Bus Buskoppler. But I can't seem to find a way to read and or write to the KL1104 and KL2134 K-Bus Busterminals.
Even more strange is that Beckhoff tech support (in Belgium) says to find help elsewhere :?
Mmm, anyway using Edwin's advice I downloaded the MDP for the EtherCat K-Bus kopplers BK1120 ... what do you know the XML files for the I/O modules are included in this package :?
I can load the modules in the devices tab under the BK1120;
But can't seem to place the modules under the BK5120 ...
Is there maybe a workarround by writing to specific registers? How do I determine the addresses to read / write to access the I/O modules?
PostPosted: Thu Jan 24, 2019 11:30 am
Hi all,
Just for future reference and it might help others ...
When the correct eds file for the BK5120 is loaded in the device repository and in the devices tree one must add the mappings under the PDO tab for the BK5120 Buskoppler. The whole process is kind off self explanatory. At least once you find the nerve to click on the add mapping button. :oops:
Kind regards,
Koen
