It is currently Thu Jan 23, 2020 7:05 pm
 Post subject: Raspberry + Ethercat
PostPosted: Fri Jan 11, 2019 8:25 am
I am using a raspberry PI3+ with codesys v3.5 SP14.
I have success to compile and execute a small project to the PI. I can control the program in using the webvisu with the ethernet port too.
Now, I would like to use an Ethercat slave (Beckhoff EK1100). On my PI, I have only one Ethernet port and I think it may use only for Ethercat bus (Ethercat master) . So in this case, it will not be possible to access to the PI with ethernet. So I need to have 2 ethernet ports.
What is the best solution to access to the PI in Ethernet and to use Ethercat on the PI?
Thanks for your help
 Post subject: Re: Raspberry + Ethercat
PostPosted: Fri Jan 11, 2019 9:38 am
You can take almost any USB-to-Ethernet adapter. We do so here, too. According to my experience all the (3 or 4) different adapters I have used for this purpose worked well.
Roland Wagner
Moderator
PostPosted: Fri Jan 11, 2019 9:52 am
I tried one but I didn't work. It is possible to ping the ethernet port (usb adaptater) but the communication crashs after several seconds.
Any configuration to set inside the PI?
Roland, do you know if there is a tutorial somewhere to add an ethernet port with an adaptater?
PostPosted: Fri Jan 11, 2019 10:55 am
the other way could be :
- a wifi dongle connected on one usb port from the pi
https://www.kubii.fr/claviers-et-peripheriques-usb/1471-dongle-wi-fi-officiel-raspberry-pi-kubii-3272496004825.html
- connection between my laptop and the pi, to download the codesys program for example, on the wifi network
- connection between the pi and the EK1100 from Beckhoff for the Ethercat bus on the Ethernet port
It could work??
PostPosted: Fri Jan 11, 2019 1:08 pm
yes sure... this will work too!
PostPosted: Mon Jan 21, 2019 11:11 am
I used this adaptor successfully
https://www.amazon.co.uk/UGREEN-Etherne ... rnet&psc=1
Users browsing this forum: Andreas Kehrer, phenixrb and 4 guests
