It is currently Tue Aug 20, 2019 8:12 am
PostPosted: Wed Jan 09, 2019 3:47 pm
I am stuck on an issue, where I am trying to do some coordinated motion with two drives. Following instructions from the help file, both drives are power enabled then the attempt to Enable Group FB status is Busy. I noticed that the axis group is giving a license error. I have a softMotion license. Is there something else required?
PostPosted: Wed Jan 09, 2019 5:13 pm
CNC/Robotic license is needed...!
https://store.codesys.com/codesys-softm ... nc-sl.html
See details on the store description.
https://www.codesys.com/products/codesy ... n-cnc.html
CODESYS SoftMotionCNC+Robotics: In addition to the POUs made available in CODESYS SoftMotion, CODESYS SoftMotion CNC contains POUs for CNC functionality, different kinematic transformations with the appropriate visualization templates, PLCopen Motion Part 4 and editors for 3D CNC and the robotics axis group editor.
PostPosted: Thu Jan 10, 2019 3:48 pm
Thank you for the response. I have moved to an unlicensed machine to try and run in demo mode and I am still having the same issue. The axis group enable is stuck on Busy. Do you have a suggestion to diagnose this problem?
PostPosted: Thu Jan 10, 2019 5:06 pm
hi,
dis you check this example here:
"c:\Program Files\CODESYS 3.5.14.0\CODESYS\Projects\SoftMotion\4.4.0.2\Examples\Tutorial\Robotics_PickAndPlace_without_Depictor.project"
in PROGRAM Robot there is a statemachine… you need to check:
