It is currently Thu Feb 20, 2020 4:14 pm
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 Next
PostPosted: Fri Dec 28, 2018 9:03 am
Hi guys, i have some problems when i try to connect my Beijer HMI X2 control with Ek1100 and it's module via etherCAT. I've read some instruction between Ras Pi and Beckhoff and followed them but nothing change. Anyone have any ideas please tell me. Thank you so much!
PostPosted: Fri Dec 28, 2018 4:53 pm
could you give us a screenshot of the plc logger?
PostPosted: Thu Jan 03, 2019 8:58 am
What is the PLC logger?
PostPosted: Thu Jan 03, 2019 11:14 am
Hello
1. Which build are you using in the X2 Control?
2. Do you remember if you selected 'Yes' or 'No' to the DC (distributed clock) question when you installed the Codesys PLC?
3. Have you referenced the correct library versions? Beijer use version 3.5.10.10
4. If you are able to post your code, I can look.
ph0010421
PostPosted: Fri Jan 04, 2019 3:00 am
Hi ph0010421,
I don't understand your 1 question, sorry I'm new with beijer.
I can't remember because I installed long time ago.
I think it right, I can connect codesys with beijer, I've tested it, when I changed tag value in laptop with codesys the tag value in the panel changed too.
I didn't write any code in this project, I want to check the connect first
PostPosted: Fri Jan 04, 2019 9:01 am
PostPosted: Fri Jan 04, 2019 9:41 am
Hi Edwin, i didn't think there are a lot of error like this. ph0010421 is right, maybe my library have some problem.
PostPosted: Fri Jan 04, 2019 10:44 am
did you set/browse the correct network interface which is connected to your slaves?
PostPosted: Fri Jan 04, 2019 5:21 pm
I agree with Edwin.
Browse for the network adapter.
If you did NOT select DC then it's called ENET1.
This relates to the physical LAN A port.
PostPosted: Sat Jan 05, 2019 2:25 am
Hi, I already use browse to pick X2 Ethercat (lan A).
PostPosted: Sat Jan 05, 2019 12:05 pm
Which version IDE are you using?
PostPosted: Mon Jan 07, 2019 2:19 am
I use CODESYS V3.5 SP13 Patch 1 and iX Developer 2.40 SP1 for panel.
PostPosted: Mon Jan 07, 2019 5:23 pm
Ok. Which libraries has it used? It will default to use the latest and this is not what we want.
The compiler needs to be set to 3.5.10.10 and all libraries need to be 3.5.10.10 or earlier.
As I said earlier, if you post your project, I can have a look for you.
Kind regards,
ph
PostPosted: Tue Jan 08, 2019 2:54 am
Kind regards,
ph
Hi ph0010421, here my project. If you can fix it for me, i'll very appreciate it.
And like you said, I updated the libraries to some new version not 3.5.10.10. I'll try to edit it.
Thanks for you help!
PostPosted: Tue Jan 08, 2019 9:39 am
Please can you SaveAs 3.5.10.10
Users browsing this forum: Andreas Kehrer, SGronchi and 11 guests
