It is currently Tue Nov 19, 2019 4:09 am
PostPosted: Mon Dec 10, 2018 3:35 pm
I have made an analog function block that will do the analog stuff. If it is possible i want to set and reset the function block with a digitial signal from a button. can anyone give me some advice on how to do this? I can't really find anything that will make me able to combine the digital and analog signals.
PostPosted: Mon Jul 29, 2019 2:35 pm
Hi.
I sugest to do it in FBD using SEL function block. It works like IF function. It has got 3 inputs and 1 output. First input is a trigger (your bool varable). When bool=FALSE, then output takes 2 input, when bool=TRUE, then output takes 3 input. So solution is like this. 1in=bool variable, 2in=var_in_out, 3in=your_analog_signal, out=var_in_out. It will work like a buffer.
