It is currently Tue Feb 25, 2020 9:59 pm
PostPosted: Mon Dec 03, 2018 3:33 pm
Hello everyone:
Thanks for this, when I control motor with codesys 3.5.9,I get a question of "SMC_DI_GENERAL_COMMUNICATION_ERR" at the time of Initializaing the 402axis in sync period of 8ms. and I find that if I set the period less than 8ms, just as 7ms, all things is ok, but when I set this value more than 8ms,then I get this error in Initialization phase.
Does anyboby have occured the same question?
Thanks again.
PostPosted: Fri Dec 07, 2018 9:53 am
Hi cookiy,
This is strange, I dont have a real answer but I would check the tasks' configurations. Is the initialization running under the fieldbus task? Or in a different one? I would prefer having everything running under the fieldbus task.
If fieldbus is Ethercat, are you using a distributed clock? Is this correctly set (also on the drive side).
Regards, Omar
PostPosted: Mon Jan 21, 2019 1:20 pm
Omar Ampyx wrote:
Hi cookiy,
Regards, Omar
Thanks very much!
Yes, the fieldbus is EtherCAT, what is so strange that it is ok in most time of getting up, but failed in startup occasionally
