How to switch visualization in library by code?
dongdong
2018-10-17
2018-10-17
  • dongdong - 2018-10-17
    I Switch library internal visualization by the way as shown below.
    It works well before,but now it doesn't work.Could you please tell me if it's right ? Or could you please provide me a well working way?
    Method 1:
    VisuElems.g_VisuManager.SetMainVisuGlobally(VisuElems.Visu_ClientType.TargetVisualization ,stVisu := VisuName);
    Method 2:
    VisuElems.CURRENTVISU:=VisuName;
    Best regards.
    IMG: lib.png
  • e.kislov - 2018-10-17
    I think you should use LibraryNamespace in VisuName:
    VisuName := MyLibraryNamespace.Screen1;
    e.kislov hat geschrieben:
    Hi e.kislov,
    Thanks for your reply.
    I have used the library namespace, but I still can't switch. Please note the selected content in the attached image.
    Yes, you're right.
    I try it and as i see Library Visu Switching works only without mark "Internal" (it was expected) and only with visu elements (InputConfiguration - OnMouseClick - Switch Visu), not from code...
