It is currently Thu Jan 17, 2019 7:58 am
 Post subject: OPC DA Server using V3
PostPosted: Wed Sep 26, 2018 6:14 pm
this is my first time working with CODESYS Environment as well as communicating using OPC.
I have a project to connect a PLC to a plant simulation software which only supports OPC DA, so I downloaded and installed CODESYS OPC DA Server SL Demo software from the store.
As I understood, I need to configure the DCOM settings on my Windows to make the connection works, and according to the FAQ (viewtopic.php?f=22&t=5649&p=10047#p10047), there should be an item called OPC Server for CoDeSys V2.0 or CoDeSys OPCServer DA under the DCOM settings but I cannot find them in my computer.
Any ideas on how to set it up with CODESYS V3?
Also, any suggestions regarding DA communications will be much appreciated.
Regards,
Setyadi
