It is currently Tue Aug 20, 2019 2:59 pm
PostPosted: Fri Apr 13, 2018 5:22 am
Hello evrybody.
there is many post about the SysProcess library and particulary about the "Execute Command".
I 've follow some exemple read in this forum and it works fine on my Raspberry pi, but only the command which doesn't need to be execute in the graphic interface.
I explain :
First i adjust the CODESYSControl.cfg to
[SysProcess]
Command=AllowAll
If i try to excute :
command1 := 'reboot';
"SysProcess SysProcess Execute Command2(pszCommand:=command1 ...)
it works fine
and if i try to excute :
command1 := 'leafpad';
nothing append
if run the command 'leafpad' in the rasbperry command terminal, it works.
So is it possible to execute command or program with graphic interface.
Thank you.
PostPosted: Fri Apr 13, 2018 5:36 am
if this is >=3.5SP11 there is the section for doing this in /etc/CODESYSControl_User.cfg
so move your setting/section from /etc/CODESYSControl.cfg to /etc/CODESYSControl_User.cfg
PostPosted: Mon Apr 16, 2018 5:04 am
Hi Edwin.
I use the last one so : 3.5.12.20
I tried to move the setting
[SysProcess]
Command=AllowAll
from /etc/CODESYSControl.cfg to /etc/CODESYSControl_User.cfg.
but same result.
it seems that the runtime process does not have the rights to execute graphical applicaton
PostPosted: Fri Nov 30, 2018 6:02 am
Hi i have exactly the same problem with Linux Runtime and RPI Runtime.
Only the "no graphic" command work.
I tried to run with "su -l user -c 'app' command but it doesn't work too.
Does Someone know a solution for that ?
Thank you
