It is currently Mon Feb 17, 2020 11:27 pm
PostPosted: Mon Mar 19, 2018 2:18 pm
I am using V2.3 and yesterday had to re-install windows 10. Since then I am missing the 'open from plc' selection button - see attached file.
I have tried different versions of V2.3 as well as different screen resolutions and text sizing, but all to no avail. Everything was working fine before re-installing windows so I am assuming there are some missing C++ files or equivalent.
Any help would be appreciated.
Thanks,
Paul.
PostPosted: Tue Apr 03, 2018 8:01 pm
can't you downgrade to Win7 or at least run a VM?
PostPosted: Wed May 02, 2018 6:48 am
Many thanks - it works ok with a VM, but it had worked for more than a year with Windows 10 without issue. It was only after needing to re-install - essentially an 'out of the box' re-install due to Windows crashing during an update - that the radio button disappeared.
Will continue with the VM although it is not as convenient due to screen resolution issues (I am using a Microsoft Surface Book and the screen resolution is not always good at handling the older non-Microsoft apps)
cron
