It is currently Thu Jul 18, 2019 6:13 pm
PostPosted: Fri Mar 16, 2018 6:37 pm
Im working on a project and I am considering using CANopen, is it possible to use a USB to CAN converter cable from Kvaser with CODESYS?
Here is the output of udevadm monitor --udev
UDEV [1409309.515608] add /devices/pci0000:00/0000:00:1d.7/usb2/2-4 (usb)
UDEV [1409309.520826] add /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4:1.0 (usb)
UDEV [1409309.525023] add /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4:1.0/net/can0 (net)
UDEV [1409309.532863] add /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4:1.0/net/can0/queues/rx-0 (queues)
UDEV [1409309.539158] add /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4:1.0/net/can0/queues/tx-0 (queues)
I could also use EtherNet/IP, would this be a better idea because of the ethernet port being easier or more reliable to access from CODESYS?
Thank You!
PostPosted: Mon Mar 19, 2018 12:04 pm
you want to use this USB to CAN for
doing CANopen by the Raspberry PI Runtime?
PostPosted: Tue Mar 20, 2018 2:52 am
Yes. Is it possible?
My reasons are:
I have a lot of experience with the Kvaser hardware, I also have lots of it available.
I'd like to use something that does not come in the "hat" form factor to allow use with the compute module.
I'm looking to use parts that are from a "major" manufacturer to help guarantee long term availability.
Thanks!
PostPosted: Tue Mar 20, 2018 11:26 am
if you manage to build on the Raspberry PI a Socket CAN kernel module
for the Kvaser Hardware, this might work but not easy.
PostPosted: Mon Feb 11, 2019 1:22 pm
Edwin Schwellinger wrote:
Hi did you manage to use it ?
cron
