It is currently Wed Feb 19, 2020 4:29 am
 Post subject: Codesys Control RTE
PostPosted: Fri Feb 02, 2018 9:21 am
i'm trying to run Codesys RTE on an industrial PC with Win7. The installation is ok and I can also Start the PLC.
I make a new project on my laptop with the Codesys Control RTE Devive but I'm not able to can connect with the devive.
I can ping the industrial PC but the Codesys network scan didn't see any device.
Where is my fault, what i miss to do?
thanks
Simone
 Post subject: Re: Codesys Control RTE
PostPosted: Fri Feb 02, 2018 2:18 pm
- check if you use Control RTE 64Bit - if yes you need to add the 64Bit device in the CODESYS project an vice versa..
- check if the RTE is properly startet by - go with the mouse on the Task tray Icon - you should see the Network address which have been assigned.
- remove the filter in the CODESYS scan Dialog/Settings to see all found devices on your network.
