It is currently Thu Jul 18, 2019 4:23 am
 Post subject: Android sensors setup
PostPosted: Mon Jan 29, 2018 5:34 pm
Has anyone had experience with the android sensors add on. I have a raspberry pi with codesys. I can't for the life of me get the android phone to send updated values to the codesys controller. If anyone has a basic example or has done this please show me the way.
PostPosted: Mon Jan 29, 2018 7:50 pm
just use the Project from CODESYS store.
Install it here:
After install you'll find the project here:
"c:\Users\<YourWindowsUserName>\CODESYS Examples\SensorAppForAndroid\1.4.0.0\AndroidSensorApp.project"
-> then update the Project by rightclick to the project tree to your plc - set current compiler and current visu Profile.
one remark you need to remove the library netvarupd 3.5.5.0 from the Project (this seems to be a bug) it pulls automatcally current Version on compile after doing this.
PostPosted: Mon Jan 29, 2018 9:32 pm
One problem I have been having with the example program is that it includes two devices, Datagenerator and receiver. Do I load both devices to the raspberry pi and which one do I run?
PostPosted: Mon Jan 29, 2018 9:59 pm
You just need to download the second one... first one is only placeholder for the netvarlist.
PostPosted: Tue Jan 30, 2018 4:56 am
Thanks for the help so far but I am still unable to get it to work. I am getting a bunch of errors when I try to download to the device. Lets say I wanted to create a new project and just monitor screen rotation. How would I go about setting that up?
PostPosted: Tue Jan 30, 2018 7:34 pm
the most important is this list here:
This must 100% fit, because These liste is exactly used in the android app to send the values:
The upper Application is only a dummy application to have this list accessible as receive list.
//This gobal variable list is received via the network.
//Sender: NVL [SensorDataGenerator: PLC Logic: DataGenerator]
//Protocol: UDP
VAR_GLOBAL
   wVersion: WORD := 16#00_01;
   wCounter: WORD;
   dwFeatures: DWORD;
   Data: SensorValues;
   strCommand: STRING(70);
PostPosted: Thu Feb 08, 2018 5:13 pm
Do I have to use the devices hotspot to connect the controller, or can they both just be on the same network interface?
PostPosted: Mon Feb 12, 2018 7:28 pm
they need to be in the same network (android and plc)
