It is currently Tue Aug 20, 2019 2:58 pm
 Post subject: PI3 B+ MCP2515 CAN ERROR
PostPosted: Mon Jan 08, 2018 4:24 pm
Can interface communication is all right in the terminal, but it is wrong in the codesys.
I have configured the can interface in the way in the forum, but the problem couldn't be solved.
I have no way to deal with the problem, please help !
PostPosted: Tue Jan 09, 2018 5:20 am
is this 3.5SP12 Version?
Guess you need an entry in your /etc/CODESYSControl_User.cfg for example the following entry
where the script is located (this is like it is the beaglebone black done) :
[CmpSocketCanDrv]
ScriptPath=/opt/codesys/scripts/
ScriptName=rts_set_baud.sh
Edwn
PostPosted: Tue Jan 09, 2018 5:52 pm
Thank you very much! The problem seems to have been solved! And I'll test it in detail later.
PostPosted: Thu Jul 18, 2019 2:46 pm
Hi there!
I am also trying to set up the same circuit as seen in the image attached by you.
Can you please tell me the steps(commands) to be taken to be able to set up can1?
I managed to set up can0 using the commands mentioned in the following link:
https://www.raspberrypi.org/forums/viewtopic.php?t=141052
I also changed the file pathway for the script as mentioned by Edwin.
However, I am now blind to be able to set up can1, such that two MCPs can run on a single raspberry pi.
It would be very helpful if you told me about what you did.
PS: I am not from Linux background.
Thanks again for your time!!
