It is currently Tue Jul 23, 2019 2:13 pm
PostPosted: Tue Dec 12, 2017 11:00 am
1. Is it possible to disable some Static Analysis errors/warning when my POU is implemented in CFC? I know in ST code I can use pragmas {analysis '-...'}, but unsure if anything similar is possible on CFC code.
2. In some cases Static Analysis gives me warnings and I cannot disable them with pragmas. For example:
I generate a persistent variables list like below:
{attribute 'qualified_only'}
VAR_GLOBAL PERSISTENT RETAIN
   {attribute 'analysis' := '-12'}
   g_xCheck:      BOOL := FALSE;
   g_sText:      STRING := 'abc';
Then I place these variables somewhere in a Visualizaiton. The Static Analysis still reports "SA0012: g_xCheck could be declared as constant." - despite of the usage of pragma {attribute 'analysis' := '-12'}. I would like to disable it. What am I missing?
