It is currently Fri Feb 21, 2020 8:07 pm
 Post subject: BBB with VSCOM USB-CAN
PostPosted: Mon Jun 12, 2017 3:54 pm
Hello, support!
Is it possible to use USB-CAN converter with BeagleBone Black?
Producer of this device is VSCOM http://www.vscom.de/usb-to-can.htm
Standard Phillips controller SJA1000 and transceiver TJ1000 are used for data transmit. But from OS side it emulate serial port.
Thank you.
PostPosted: Thu Jun 15, 2017 6:32 am
Online
if you manage to run a socket can implementation on this maybe yes.
But would recommend to use for CAN the local onboard CAN.
Only the bus Transceiver need to be on an additional cape for example this here(maybe many others are possible to use:
http://www.waveshare.com/wiki/RS485_CAN_CAPE
Users browsing this forum: Edwin Schwellinger and 0 guests
