It is currently Wed Feb 26, 2020 11:17 pm
PostPosted: Wed Jan 11, 2017 8:06 pm
Hello!
I am trying to etablish a connection to a Rexroth RC6_9_20 with Bodas Design 3.0.17.
I want to read out the program from the RC, and save it on my Computer
Could someone please tell me if there is a kind of tutorial here at this forum how to set this up?
Here is what I do:
File - Open - Open project from PLC - PLC - Target Setting _ RC6-9 20 Standard V1.9 - Interface - Peak PCAN-USB - Devicetype RC4-6/22 - Scan
I cannot connect, any ideas what`s wrong?
Thanks in advance !
Newbe
PostPosted: Thu Jan 12, 2017 12:49 pm
The project must be saved on the device, otherwise it is impossible to open it.
a program is compiled in the PC and send to the PLC as a machinelanguage, so you can not download from the device as a compiled file is unreadable (for the most people)
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Thu Jan 12, 2017 10:14 pm
Thanks for information!
PostPosted: Fri Jan 13, 2017 9:56 pm
Ok, so I`ve been able to connect to the RC.
Used Bodas Service 3.5 to flash an existing HEX. file into the RC, and then downloaded a test program.
When opening Bodas design after doing a "rebuild all" I got a message "Not found HEX-File:C:\ xxx\xxxx"
Have I done something wrong here?
I could go online without problems.....
PostPosted: Sun Jan 15, 2017 4:46 pm
this is outside the scope of codesys,
however have a look at settings if the compiler makes a correct hex file and obvious where it is stored.
check the project directory.
shooter@home.nl
computer shooter
paul deelen
phone +31736139136
PostPosted: Sun Jan 15, 2017 9:16 pm
Thanks, I will try!
