It is currently Thu Jan 23, 2020 12:26 pm
PostPosted: Tue Nov 22, 2016 10:21 am
Hello all,
I have an array of x bytes. I want to process this data somewhere else in my program so I want to use pointers. I want to be able to increment the pointer address in an easy way. I know have the following code:
______________________________________________________________________
receivedData : ARRAY [0..MAX_RECEIVE_TCP_SERVER] OF BYTE;
processCommand( ADR(receivedData[6]) );
FUNCTION processCommand : BOOL
VAR_INPUT
dataPtr : POINTER TO BYTE;
channel: BYTE;
value: UINT;
state: BYTE;
channel := dataPtr^;
dataPtr := dataPtr + 1;
value := dataPtr^;
value := value + (dataPtr^ * 256);
state := dataPtr^;
dummyFunction(channel, value, state);
Is there an easier way to increment the pointer address? I would prefer to have something like this, but I don't know if this is possible:
dummyFunction(dataPtr[0]^, dataPtr[1]^ + dataPtr[2]^ *256 , dataPtr[3]^);
PostPosted: Tue Nov 22, 2016 12:44 pm
Instead of defining a pointer to byte, define your pointer as:
dataPtr := POINTER TO ARRAY [0..MAX_RECEIVE_TCP_SERVER] OF BYTE;
Then you can access your data with array indexing like you wish.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Thu Nov 24, 2016 8:08 am
Thanks for your reply. Unfortunately, this is not possible (error 4110, '[<index>]' needs array variable).
Other solutions, or is my implementation wrong: dummyFunction(dataPtr[0]^, dataPtr[1]^ + dataPtr[2]^ *256 , dataPtr[3]^);
PostPosted: Sat Nov 26, 2016 8:06 pm
I am not by my computer, but I believe you need to dereference before index: dataPtr^[1].
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Wed Nov 30, 2016 3:40 pm
Works! Unbelievable I didn't try that... Thanks very much!
PostPosted: Wed Nov 30, 2016 7:45 pm
If you get tired of dereferencing your pointer, you can use REFERENCE TO instead of POINTER TO. Check the help for more info.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
