It is currently Thu Sep 19, 2019 3:20 am
PostPosted: Wed Nov 09, 2016 5:06 pm
I am trying to get a basic check dialog in place for a change to a critical parameter. I have a requirement that a before a particular change can be made the current user must re-enter their password, and a user from a 'supervisors' group must enter their name and their password. See below for an image. When OK is pressed I want to revalidate both passwords and then take appropriate action.
I'm struggling to get enough visibility of how the User Management is structured to be able to put this together.
I have inspected the VisuUserMgmtDialogs.library and found that these dialogs reference the UserManagement system through dialog parameters. I haven't found out how to access what these are set to when the dialog is called, as the user management dialogs are a special case.
I have looked through the VisuUserManagement library and found the VisuUserMgmt function block, which I think has the Methods I want CheckLogin and CheckLoginWithGroupID - but I'm not sure these are correct - as I don't want to login - just check the password.
I also need to understand how users and group ID's relate. Somehow I ned to identify to the dialog which group of users is the 'supervisors ' group.
I'm not sure if I'm just not finding the relevant documentation, or reference project. Any tips much appreciated.
PostPosted: Wed Apr 25, 2018 8:08 am
Hello David Cozens
I Need to automatic login with an existing user.
Do you have an example where i can see how to do this.
I do:
fbVisuUserMgmt : VisuUserManagement.VisuUserMgmt;
stVum_User_Act: VisuUserManagement.VUM_User;
fbVisuUserMgmt();
stVum_User_Act := fbVisuUserMgmt.GetCurrentUser();
the stVum_User_Act is always empty..
will be glad if you can help me
Greatings
G√ľnter Saiko
