It is currently Sun Aug 25, 2019 9:57 am
PostPosted: Mon Oct 31, 2016 7:41 am
Codesys Forum,
I would like to use the Raspberry Pi with an SPI CAN module to establish CAN communications. However, I'm unclear on a few points:
With "CODESYS Control for Raspberry Pi SL" is bi-directional CAN communications supported or is it only possible to monitor the CAN bus?
I'm considering the following CAN modules. Can anybody recommend one over another?
SK Pang Electronics - PiCAN2
MikroElektronika - CAN SPI click 3.3V with Pi 2 click SHIELD
IndustrialBerry - CanBerryDual V2.1
If CAN communications is the only requirement is the Beaglebone a better alternative?
Regards, Ben
PostPosted: Wed Nov 09, 2016 1:15 pm
CODESYS supports SocketCAN communication. I managed to get CODESYS CAN communication working on a Raspberry Pi 3 with CanberryDual. However, for some reason it only works if one mcp2515-overlay is configured in /boot/config.txt, so only one CAN bus is working. Still figuring out, why that is the case and whether it is a CODESYS or SocketCAN problem. Any help on this appreciated.
PostPosted: Tue Nov 15, 2016 2:00 pm
I have the PiCanV2 from Skpang it took some browsing of the forums here, but there is a really good thread on it that will help you get it working. you can compile socketcan into you image and configure the codesys control to auto load on CAN1. I actually have an image that I would be more than happy to share if you send me your information. as a side note I am NOT a Linux or Codesys expert. I have just compiled the bits and pieces that the community has provided to make a working system.
so far I have it running on a Raspberry PI B, and Raspberry PI 2 B. I don't have a Raspberry PI 3 yet to get it working but I have been told that there is little difference in the configurations.
I do know however that the Device version 3.5.9.20 doesn't work for me. I have to use an older device version in Codesys V3.
I know this was a bunch of random info put into a not so nicely formatted post but I hope it somewhat helps.
PostPosted: Tue Jan 09, 2018 4:31 pm
@bmunsil
I have a problem with PiCanV2 from Skpang
Codesys gives me the error message "Bus not running"
But the canbus is working on the raspi, I can see messages by using candump can0.
Codesys Version is 3.5.12.0.
Can you tell me where you found the solution for your problem?
Cheers,
CanBohr
PostPosted: Thu Jan 11, 2018 6:54 am
to have this script executable is mandatory:
viewtopic.php?f=21&t=8463#p20132
#!/bin/sh
BITRATE=`expr $2 \\* 1000`
ifconfig $1 down
echo ip link set $1 type can bitrate $BITRATE
ifconfig $1 up
PostPosted: Wed Mar 27, 2019 4:33 pm
I have similar problem with PiCanV2 from Skpang
Canbus is working on the raspi, I can see messages by using candump can0.
Have installed Codesys Version is 3.5.14.0.
Downloaded CANbus example from the store.
Unfortunately I can not get the example working.
Can you help me please to get this example running on Raspberry 3 controlled with Codesys?
Cheers,
