It is currently Mon Jan 27, 2020 5:22 pm
 Post subject: Licensing question
PostPosted: Fri Oct 07, 2016 5:22 pm
I just bought a license and didn't realize I needed a security key... will any USB dongle work, or do I have to buy the one from CodeSys? Also, does the key go into my computer, or does it go into the RaspberryPI?
 Post subject: Re: Licensing question
PostPosted: Fri Oct 07, 2016 6:19 pm
you have the choice, either activate the ticket as 'softlicense' then you will not need this runtime key.
(http://store.codesys.com/accessories/co ... mpakt.html)
Using the runtime license key is optional - if you need a portable license (the PI which has the key plugged is licensed)
then USB Runtime Key is a good option.
See the how to license FAQ:
viewtopic.php?f=22&t=5641&p=10688#p10688
and do not Forget to generate your backup license after activation.
PostPosted: Wed Jul 05, 2017 3:47 am
Dear Edwin,
Which licensing(Soft license or compact key-USB dongle) will be better to port the license from one system to another?
In case of hardware failure or some some other reason, if I would like to carry the license from one system to another(for example BeagleBone Black).
Regards,
Kumar Eswaran
PostPosted: Wed Jul 05, 2017 4:58 am
a portable license is only possible if you use the Runtime Key as license store.
https://store.codesys.com/accessories/c ... mpakt.html
PostPosted: Sat Aug 19, 2017 3:46 pm
Hi guys....
Is there any possibility to transfer licence from RPi2 to RPi3 ?
PostPosted: Thu Apr 19, 2018 4:50 pm
Hello people,
How can I activate Modbus TCP license for my device?
I have a device where I'm using Modbus TCP communication but it shown in the Codesys with orange: it is a demo version if I'm right.
In case I want to activate should I by the one from the store called as CODESYS Modbus TCP Master SL and I attached as picture?
After what I will get? A 3S.dat file? There is one already on the device I guess I shouldn't overwrite that, or? Finally if I go to the PLC Settings and Edit Licenses I got an error message, attached as picture. Or I should write that file to a pendrive?
Thank you,
Gergö
PostPosted: Sat Apr 21, 2018 6:10 am
which plc are you using?
Manufacturer need to support 'single licenseing' mean a codemeter component should be build in.
Then a runtime USB Key could be used for the license.
I would recommend to ask the plc manufacturer for his advice.
Users browsing this forum: SANTYS7 and 5 guests
