It is currently Tue Jan 28, 2020 6:44 pm
PostPosted: Fri Sep 30, 2016 2:22 pm
I have a CNC program (attached) created with DXF import. It works fine.
But if I add a pair of G52(round path) - G50(end of round path) commands to it and try to save it (Write CNC program to file), Codesys 2.3 displays the following message
Error during interpolation
The program causes the following error while interpolating:
Too many recursions in the interpolator
Cancel Saving?
Yes No
Then if I execute the CNC program, it is processed OK - angles are rounded, drives follow the path, everything looks fine....... but M-commands are not executed.
If I remove the G52 / G50 commands, everything goes back to normal and M-commands are processed.
Any idea why this happens? Are the PLC resources insufficient to handle the path with roundings?
And more important, is there any way to handle this?
Thanks for any suggestions.
I use Codesys 2.3.9.42 provided by Festo, with Festo PLC CPX-CEC-M1
PostPosted: Fri Sep 30, 2016 8:01 pm
it makes to many calcs, lower the precision
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Sun Oct 02, 2016 6:58 pm
thank you for the reply, but how do you modify precision?
Do you mean the Extras / Set epsilon values... menu, or something else?
PostPosted: Mon Oct 03, 2016 8:30 pm
you will need to have a balance between precision and result.
shooter@home.nl
computer shooter
paul deelen
phone +31736139136
PostPosted: Wed Oct 05, 2016 8:06 am
OK, thanks.
But how do you change precision?
