I'm wanting to flash a stack light, and it looked like the BLINK function block in util.lib was a perfect fit for that. Alas, I am getting no blinkage when setting ENABLE to true. ST code as follows:
  blinker : BLINK;
  bEnableAT%IX2.0 : BOOL;
  bitstateAT%QX2.0 : BOOL;END_VARVARRETAIN
  bStarted : BOOL;END_VAR
  IFbStarted=FALSETHEN
    blinker.TIMEHIGH :=t#1s;
    blinker.TIMELOW :=t#1s;
    bStarted :=TRUE;
  blinker.ENABLE :=bEnable;
  bitstate :=blinker.outANDbEnable;
The docs for BLINK make it look like a pretty simple FB to implement, so am I missing something totally obvious?
Hi guys,
Looks like you aren't actually calling the function block, just initializing it's parameters.
YES
You will have to call the Function block then it will work...
CODE:
BLK(ENABLE:=start , TIMELOW:=t#0.5S , TIMEHIGH:=t#0.5s , OUT=>Status );
Variable:
BLK: BLINK;
start: BOOL;
Status:BOOL;
Thanks a bunch, guys.
