It is currently Sat Dec 07, 2019 2:49 pm
PostPosted: Mon May 02, 2016 11:51 am
I have two apps running on a PLC. I want to redownload one of the applications without affecting the other running application. I use some thing like the following in teh script
app = projects.primary.active_application
online_app = online.create_online_application(app)
online_app.login(OnlineChangeOption.Never, False)
This should force download the code and not disturb the "foriegn app"
When ever I try this I get a Login Failed error.
Where as when I try
This works and it goes ahead and deletes the other application.
Any help is appreciated
PostPosted: Fri May 13, 2016 1:39 pm
As it's some time without a reply: has your problem been solved in the meantime?
Regards,
Markus
PostPosted: Wed May 18, 2016 12:22 pm
No the problem described above is still there.
I have split my script into two scripts, where the user runs the first script then manually logs in properly and then runs the second script. But this is a clunky way to do it.
Users browsing this forum: georgetsag and 0 guests
