It is currently Wed Feb 26, 2020 11:23 pm
PostPosted: Wed Apr 27, 2016 10:08 am
I am using CODESYS V3.5 SP8 Patch 2
Is there a way to import / export Global variable list using CSV files?
So we can generate variable lists in Excel and then import them in CODESYS.
with kind regards
PostPosted: Wed Apr 27, 2016 10:33 am
When you use tabs in the declaration of the variables in CODESYS (textual view), then you can just copy/paste the variables to/from Excel.
Excel will use the Tabs to place the text in individual columns.
PostPosted: Tue Dec 18, 2018 2:48 pm
I have been working on this task for few day and I had solution for it. Following the steps:
1/ Create Format of CSV file from Excel
Need to have header: TextList ID Default (and optional different languages, for instances)
In the TextList column, insert textlist name for every rows.
2/ Create UTF-8 CSV to keep the Unicode font when importing to CODESYS.
This step is required if you want to import UTF-8 text such as Germany characters
- Create Excel content as step 1
- Save As → Save as Type: CSV (Comma DElimited)(*.csv) → Tools → Web Options → Encoding → Save this document as: Unicode (UTF-8) → Fonts → Characters Set: Multilingual/ Unicode/Other Script → OK
3/ Add CSV file into a new text list of CODESYS.
- Right Click Application in CODESYS --> Add Object --> Text List --> Any Name
- Double Click on new Text List just created --> In Textlist Tab from Menu Bar --> Import/Export Text List File --> Choose File to COmpare or to Export --> Browse to the CSV file you created from step 2.
- Choose Import.
--> New Text List with the name in CSV file will appear.
Note:
- it is not required the ID column have to be number. You can insert words as well.
- It is required to have an exact format for assigning text index. The text should be placed in ' ' mark. Example: 'Start'.
- Case sensitive.
- When importing more lists into 1 project, CODESYS automatically add all headers in every list together.
PostPosted: Tue Dec 18, 2018 2:59 pm
Unicode/UTF-8 is not a font, it's a character encoding.
currently I'm using Notepad++ for mass import. (you can open a CSV from it, and play with nice replace functions like regex)
Users browsing this forum: andre_teprom and 5 guests
