It is currently Tue Jan 28, 2020 8:16 pm
PostPosted: Mon Jun 29, 2015 1:48 pm
I am working on a CAN diagnostic software tool that uses a PEAK PCAN USB network monitor as the interface into the CAN network. The software builds and compiles and I am able to login to the PLC (using the computer as a PLC for now). Im using 'CoDeSys_Control_Win_V3' runtime and have added a CANbus Device to my project. Upon logging in and selecting the Status Tab on the CANbus device, I see 'No driver found'. I'm guessing this is some sort of configuration issue or setting within my project that has to point to the PCAN USB driver installed on my computer. Can somebody tell me where the driver should be placed so that CoDeSys 3.5 could use it?
Things I have done:
Confirmed the PCAN module is working correctly (read, write, and filter functions work as intended)
Added a CANbus deivce in CoDeSys
Started the PLC Control in the windows taskbar
Modified the CODESYSControl.cfg file in the installation directory\\GatewayPLC (uncommented Componenet.6=CmPUSBCanDrv)
Added the PCAN_USB.SYS file into \\GatewayPLC\Driver Folder. (was already there, but I over wrote it again)
Checked for no conflicting baud rates or node ids
CANbus Device Information Tab:
Type 15
ID 181015
Version 3.5.4.0
What am I missing?
Thank You,
Vadim B.
PostPosted: Mon Jun 29, 2015 9:34 pm
if you use current CODESYS Version (V3.5.6.x) and you add
[ComponentManager]
Component.1=CmpTargetVisuStub
Component.2=CmpCodeMeter
Component.3=CmpWebServer
Component.4=CmpWebServerHandlerV3
Component.5=CmpPCANBasicDrv
to the "c:\Program Files\3S CODESYS\GatewayPLC\CODESYSControl.cfg"
it will work like a charm ;-)
Even using several Peak-USB adapter connected (several CAN bus) are possible and doing CAN View at the same time while the runtime is running will work.
PS: this is a CODESYS V3 question... will be moved to the CODESYSV3 section
PostPosted: Tue Sep 29, 2015 7:03 pm
I want to use my PEAK CAN USB dongle with 'CoDeSys Control Win V3'.
I followed Edwin's instructions and added 'Component.5=CmpPCANBasicDrv' to '\\\GatewayPLC\CODESYSControl.cfg'.
But when start my application, CANBus Status shows ' No driver found'.
Is there anything I forgot?
Next question: Is it possible to use PEAK CAN USB dongle with 'Condesys Control for Raspberry Pi'?
Please help!
Best regards,
Oleg
PostPosted: Tue Sep 29, 2015 7:58 pm
Hi Oleg,
please check on runtime startup (in the plc logger) if
CmpPCANBasicDrv component is loaded without error.
PeakUSB with Pi:
If you compile the Pi Linux kernel with socket can and enabled Peak USB modules, this should work.
Maybe the Peak System Forum give here more details:
http://www.peak-system.com/forum/viewto ... a&start=60
PostPosted: Tue Sep 13, 2016 1:15 pm
I can't get this to work either using Codesys V3.5 SP9 Patch 2 (US) + for Control Win V3.
Here is my CodesysControl.cfg
[ComponentManager]
Component.2=CmpDynamicTextUS
Component.3=SysCpuMultiCore
Component.4=CmpHilscherCIFX
;Component.4=CmpBlkDrvCanServer
The log shows CAN0 (DEVICE_NUMBER = 0): NetID = 0 CmpPCANBasicDrv
When I go online, the CANBus Status says "No driver found"
This is just using the demo version, could this be why?
Thanks,
Travis
PostPosted: Tue Sep 13, 2016 10:54 pm
No should even work with demo version!
Could you give us the whole logger
Start Control Win by console (run as admin) and /debug option for a test.
