Does RTL8111E controller supported ?
I'm interest to use Ethercat master on a panel PC that mount this controller. Is "E" char in controller name outstanding ?
I use the "Codesys Control Win V3" in the same PC with development and all running OK for:
* profinet on VMWARE Intel Pro/1000 nic.
When i try to run the same project in an Advantech PC with "Codesys Control Win V3" the Ethernet bus not work if i use the profinet.
* profinet on Realtek PCIe GBE Family Controller.
With profinet the Ethernet bus not work.
Without profinet the Ethernet bus work.
I try to run in the Advantech PC with "Codesys Control RTE V3" but then i have hardware compatibility problems.
Please help because i am in midle of project and ihave spend much of my time for tests.
Regards
for Profinet you need to install a CODESYS network driver. (same which you need to ethercat)
not sure if it does fit (you might check the hardware id's in windows device manager)
I would give CmpRTL8169Mpd a try
Control RTE:
see the Control RTE user manual for the instructions on how to install the Windows driver...
-> Windows DeviceManager networkdriver you need to replace the existing Realtek to the CODESYS Realtek Driver then add it to CODESYSControl.cfg
and after doing this a reboot is needed.
Control Win:
You need to install WPcap for using every networkdriver (manufacturer independent)
I try your instructions and work OK for Control WIN with default driver or with Codesys CmpRTL8169Mpd driver but with Control RTE works for a litle and after 1 to 10 seconds i take error exception:
Any help?
Another one tell me how to work the Serial Comms with Control RTE.
Regards
yes this is a known bug which will be solved with 3.5SP8Patch1 (release is 18th February)
If you need a.s.a.p a bugfix I could give a release Candidate for Patch1.... write to 3S Support.
For serial communication I could send an Project example if needed.
Please do something quick because i need tomorrow start the project tests at my costumer place.
Until now i have do my tests with Raspberry run time but for the final project i need to work with Control RTE.
Regards
Realtek 8139 (CmpRTL81x9Mpd)
Realtek RTL8139 (and compatible nic's) Ethernet-Contoller.
the 8100 und 8110 are compatible too.
Realtek 8169 (CmpRTL8169Mpd)
Realtek 8169/810
Realtek RTL8111B / RTL8111D
Intel EtherExpressPro1000 (CmpEt1000Drv )
Intel 82541,82547,82567,82571,82573,82574,82583V, i210, i217-LM
Intel EtherExpress PRO/100 (CmpEt100Drv)
Intel 82551,82557,82559, 82558, 82557 and 82550
This drivers are needed for using the ethercat master, profinet Controller and Ethernet ip scanner and Ethernet IP Adapter
on Control RTE.
PanelPC is: http://www.ieiworld.com/product_groups/ ... azYyLVBnng m
yes should work, if not please let us know.
Regards
Hi Edwin
Please give me instructions where to find the driver and how to use for:
Codesys Control RTE and Codesys Control Win PLC.
Regards
Control RTE:
Control Win:
Hi Edwin
Any help?
Regards
Hi Edwin
Regards
I've sent you an email...
Hi Edwin
The update of patch stops after a while because try to find the "disk:1".
Any suggestion
Regards
