It is currently Sun Jan 19, 2020 12:16 pm
Post new topic  Reply to topic  [ 59 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Mon Sep 29, 2014 9:12 pm
This should work on your SD too. copy CODESYSControl.cfg and 3S.dat to the new location of your redirected path
If you are already readonly with your system, are you sure you have changed CODESYSControl.cfg in /etc_org/ ?
This was in my case the mistake.
so remount to rw and change /etc_org/CODESYSControl.cfg and /etc_org/init.d/codesyscontrol these two path changes
-> reboot
PostPosted: Mon Sep 29, 2014 9:33 pm
With copy of CODESYS Control.cfg and 3S.dat it works.
Now i try the same with usb device.
Do you think it needs all of them changes?
Regards
PostPosted: Mon Sep 29, 2014 9:48 pm
change the path settings in /etc/init.d/codesycontrol
then move the files of /root to /media
and move /etc/CODESYSControl.cfg and move /etc/3S.dat to /media
After this works -> the make it RO part should follow.
Regards
PostPosted: Tue Sep 30, 2014 12:58 am
Hi.
I'm newbe in Linux but I tthink after many many tests that problems
begins from permissions of folders type "/etc" ,"/var" and "/media".
Finally I get it run and from third partition of sd card and from usb storage.
Regards
*The watchdog works ok.
PostPosted: Tue Sep 30, 2014 6:27 pm
I see green led of Raspberry Pi B+ flashes ( little flash ) continuously 1 time per second.
Is this normal?
Is this bad for sd card?
PostPosted: Tue Sep 30, 2014 6:42 pm
would propose to install:
apt-get install nmon
or iotop
then check if there is any write activity.
PostPosted: Tue Sep 30, 2014 7:13 pm
Nmon don't show any activity at Disk I/O.
Only my Raspberry do this flashing?
PostPosted: Tue Sep 30, 2014 9:28 pm
Some times after reboots from watchdog i lose the webvisu connection and codesys visualization.
Any idea?
PostPosted: Tue Sep 30, 2014 10:16 pm
please check the plc log for more information.
PostPosted: Tue Sep 30, 2014 10:45 pm
Do you mean "codesyscontrol.log" from "tmp" folder?
I can't understand it.
Linux version 3.12.22+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #691 PREEMPT Wed Jun 18 18:29:58 BST 2014
********* CoDeSysControl DEMO VERSION - runs 2 hours*********
machine: armv6l
timer resolution: 1nsec
1412029351: Cmp=CM, Class=1, Error=0, Info=4, pszInfo= CODESYS Control V3
1412029351: Cmp=CM, Class=1, Error=0, Info=5, pszInfo= Copyright (c) 3S - Smart Software Solutions GmbH
1412029351: Cmp=CM, Class=1, Error=0, Info=6, pszInfo= <version>3.5.5.0</version> <builddate>Jul 31 2014</builddate>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>CM</cmp> init, <id>0x00000001</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>CmpMemPool</cmp> init, <id>0x0000001e</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>CmpLog</cmp> init, <id>0x00000013</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>CmpSettings</cmp> init, <id>0x0000001a</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysFile</cmp> init, <id>0x00000104</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysCpuHandling</cmp> init, <id>0x00000101</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysOut</cmp> init, <id>0x0000010b</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysModule</cmp> init, <id>0x00000109</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysCom</cmp> init, <id>0x00000100</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysDir</cmp> init, <id>0x0000011b</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysEvent</cmp> init, <id>0x00000102</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>_</cmp> init, <id>0x00000103</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysInternalLib</cmp> init, <id>0x00000107</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysMem</cmp> init, <id>0x00000108</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysSem</cmp> init, <id>0x0000010f</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysSocket</cmp> init, <id>0x00000111</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysTarget</cmp> init, <id>0x00000112</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysTask</cmp> init, <id>0x00000114</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysTime</cmp> init, <id>0x00000115</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysTimeRtc</cmp> init, <id>0x00000127</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysTimer</cmp> init, <id>0x00000116</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysFileStream</cmp> init, <id>0x00000120</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysShm</cmp> init, <id>0x00000110</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysMsgQ</cmp> init, <id>0x0000010a</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysSemProcess</cmp> init, <id>0x00000119</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysEthernet</cmp> init, <id>0x0000011c</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= System: <cmp>SysProcess</cmp> init, <id>0x0000010e</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpApp</cmp> init, <id>0x00000002</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpAppBP</cmp> init, <id>0x00000073</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpAppForce</cmp> init, <id>0x00000074</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpAsyncMgr</cmp> init, <id>0x0000005f</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpChecksum</cmp> init, <id>0x0000000b</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpDevice</cmp> init, <id>0x0000000e</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpEventMgr</cmp> init, <id>0x0000005b</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpFileTransfer</cmp> init, <id>0x0000005e</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpIecStringUtils</cmp> init, <id>0x0000007f</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpIecTask</cmp> init, <id>0x00000011</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpMonitor</cmp> init, <id>0x00000014</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpMonitor2</cmp> init, <id>0x00000032</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpIoDrvC</cmp> init, <id>0x00000066</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpIoDrvIec</cmp> init, <id>0x0000005a</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpIoMgr</cmp> init, <id>0x00000012</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpRetain</cmp> init, <id>0x00000017</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpRouter</cmp> init, <id>0x00000018</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpSchedule</cmp> init, <id>0x00000019</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpSrv</cmp> init, <id>0x0000001c</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpBlkDrvTcp</cmp> init, <id>0x00000030</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpBlkDrvUdp</cmp> init, <id>0x00000007</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpBinTagUtil</cmp> init, <id>0x00000004</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpChannelMgr</cmp> init, <id>0x00000009</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpChannelServer</cmp> init, <id>0x0000000a</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpNameServiceServer</cmp> init, <id>0x00000016</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCommunicationLib</cmp> init, <id>0x0000000c</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCoreDump</cmp> init, <id>0x00000083</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpIecVarAccess</cmp> init, <id>0x00000060</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpPlcShell</cmp> init, <id>0x00000128</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpTraceMgr</cmp> init, <id>0x00000070</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpNameServiceClient</cmp> init, <id>0x00000015</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpChannelClient</cmp> init, <id>0x00000008</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAAAsyncMan</cmp> init, <id>0x00004007</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAABehaviourModel</cmp> init, <id>0x00004015</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAACallback</cmp> init, <id>0x00004001</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAADTUtil</cmp> init, <id>0x00004013</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAAFile</cmp> init, <id>0x00004008</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAAMemBlockMan</cmp> init, <id>0x00004003</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAANetBaseServices</cmp> init, <id>0x00004018</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAARealTimeClock</cmp> init, <id>0x00004014</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAASegBufferMan</cmp> init, <id>0x00004019</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAASerialCom</cmp> init, <id>0x00004012</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAATick</cmp> init, <id>0x00004009</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAATickUtil</cmp> init, <id>0x00004010</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAATypes</cmp> init, <id>0x00004006</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpChannelClientIec</cmp> init, <id>0x0000005d</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpNameServiceClientIec</cmp> init, <id>0x0000011d</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpBinTagUtilIec</cmp> init, <id>0x0000005c</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpUserDB</cmp> init, <id>0x00000064</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpUserMgr</cmp> init, <id>0x00000061</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCryptMD5</cmp> init, <id>0x0000006a</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCharDevice</cmp> init, <id>0x00000300</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpRasPi</cmp> init, <id>0x00002345</id> <ver>3.5.4.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpBitmapPool</cmp> init, <id>0x00000050</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpDynamicText</cmp> init, <id>0x00000051</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpVisuHandler</cmp> init, <id>0x00000054</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpVisuServer</cmp> init, <id>0x00000057</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpWebServer</cmp> init, <id>0x00000071</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpWebServerHandlerV3</cmp> init, <id>0x00000072</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCAAStorage</cmp> init, <id>0x0000007e</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpAlarmManager</cmp> init, <id>0x0000007c</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpGateway</cmp> init, <id>0x0000000f</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpGwCommDrvTcp</cmp> init, <id>0x00000010</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= <cmp>CmpCodeMeter</cmp> init, <id>0x0000007a</id> <ver>3.5.5.0</ver>
1412029351: Cmp=CM, Class=1, Error=0, Info=7, pszInfo= Dynamic: <cmp>CmpOpenSSL</cmp> init, <id>0x00000033</id> <ver>3.5.5.0</ver>
1412029354: Cmp=CmpBlkDrvUdp, Class=1, Error=0, Info=6, pszInfo= Network interface: <ipaddress>192.168.1.123</ipaddress>, subnetmask <su
PostPosted: Wed Oct 01, 2014 5:04 am
please access the webvisu in your browser and then give me a screenshot of the logger in codesys (if you do at in /tmp/codesyscontol.log - this is only flushed from time to time)
PostPosted: Wed Oct 01, 2014 7:05 am
Log.
PostPosted: Wed Oct 01, 2014 7:09 am
hi,
seems to work from logger messages... is that the case where you do not have a connection in the browser?
The error case screenshot is needed.
Last edited by Edwin Schwellinger on Wed Oct 01, 2014 9:50 am, edited 1 time in total.
PostPosted: Wed Oct 01, 2014 7:15 am
No.
I try to send a new log when the problem exists.
Regards
PostPosted: Thu Oct 02, 2014 8:14 pm
Hi Edwin.
1000 watchdog reboots in 12 hours with sd card read only and usb drive as run time host without problem!
Regards.
