Moderator3S
PostPosted: Thu Sep 11, 2014 10:53 am |
Offline |
Frequent User |
Arduino UNO IO Library for Codesys on Raspberry Pi Author: Gerhard Schillhuber Date: 11.09.2014 Version: 1.1.0.0
Top |
Moderator3S
PostPosted: Fri Sep 12, 2014 2:57 pm |
Offline |
Frequent User |
Adafruit LCD Plate ( http://www.adafruit.com/products/1110) Author: jjsmith88 Date: 12.11. 2014 Version: 1.1.0.0
Top |
Moderator3S
PostPosted: Sun Sep 21, 2014 6:46 pm |
Offline |
Frequent User |
4x20 Character LCD
Author: Werner Hinterseer, Lambda GmbH & Co. KG Date: 21.09.2014 Version: 2.0.0.0
Top |
Moderator3S
PostPosted: Sun Oct 05, 2014 5:25 pm |
Offline |
Frequent User |
Author: madax Date: 05.10. 2014 Version: 1.0.0.0
Top |
Moderator3S
PostPosted: Sun Oct 05, 2014 5:26 pm |
Offline |
Frequent User |
Top |
Moderator3S
PostPosted: Sun Oct 05, 2014 5:29 pm |
Offline |
Frequent User |
Top |
Moderator3S
PostPosted: Tue Oct 21, 2014 8:00 pm |
Offline |
Frequent User |
Author: madax Date: 21.10. 2014 Version: 1.1.0.0
PiChips 4 PWM I2C device. Tested with 100kHz and 3,3V on a L272 as H-Bridge with default settings on the eeprom.
Top |
Moderator3S
PostPosted: Mon Feb 16, 2015 8:24 am |
Offline |
Frequent User |
Author: Erikk Date: 16.2. 2015 Version: 1.0.0.0
I´ve attached my library for the SHT21.
It has an internal statemachine inside the _iState, dont know if this was neccesary but i think the symbolic status of the device changes if it isnt "10" ? It has a TON Timer of 50ms before Writing a measurement request ( i´ve only tested the No-Hold commands ). The internal state machine has these states: 10: Write Temp measurement command -> Send to state 11. 11: Read/wait for respons, when respons is found -> Send to state 20. 20: Write Humidity measurement command -> Send to State 21. 21: Read/wait for respons, when respons if found -> Send to state 10.
Every read checks the statusbit of the second byte, to check if it is the correct measurement that is read(temp/humidity), and sets or resets the xTempValid and xHumidityValid booleans. It dont use the checksum.
After a Temperature measurement request is sent, a 100ms TON is set, before doing a Read, same with Humidity Measurement, but only 40ms. If the read isnt successfull it will try again in the next cycle.
I tried withouth these timers with 4ms cycle time. On the 17th Temperature read (68ms) I got a respons from the sensor, and the 7th Humidity read (28ms). So to take some cycles of the Cpu and the bus, i think its the right way to go. But you could probably go down to ~65-70ms for a temperature read and ~30ms for a Humidity.
It also has a internal watchdog timer, which is needed if it doesnt get a respons at all (i made a short between the SCL/SDA lines and it got stuck in a reading state), when it runs out, it starts from _iState 0 (complete restart).
If you dont specify a I2C address, in _iState 0 it automatically sets the address 0x40 (decimal 64), which is specified in the SHT21 manual.
Its probably not the best written library but it works very well. Hope it will be of some use to someone.
SHT21 Humidity & Temperature Sensor
Top |
Moderator3S
PostPosted: Sat Sep 19, 2015 5:32 am |
Offline |
Frequent User |
Author: Oleg Wagner Date: 3.09.2015 Version: 1.0.0.1
MAX7219 which enables to drive up to 20 casceded (daisy chained) MAX7219 devices (7-segment displays as well as 64-LED matrices).
Following functions are included: - Display Test - Set number of digits - Shutdown mode - Set brightness/intensity - Clear Digit or Row - Clear all segments/LEDs of a device - Write particular segments of digits - Write BCD numbers - Write characters - Write multi-digit integer - Write multi-digit floats - Write particular LEDs in row - init device - all necessary methods to set up SPI communication and data transfer
A device description file is also part the library.
For first impression see attached screen shots.
I would like to share this library if there is interest (no engagement).
Update to 1.0.0.1 Version include: Extension of device description file:
- Icon added - Initialization parameters for devices: - Intensity level - Number of digits of the device - Shutdown - Display Test - Clear Device
Extension of “Initialize”-method in library with setting of above mentioned parameters
Top |
Moderator3S
PostPosted: Mon Oct 26, 2015 4:45 pm |
Offline |
Frequent User |
because i had some problems with the standard Adafruit PWM and made my own version. Sometimes i need the PWMs and / or the servo control function.
Use a Array[0..15] to send values from 0 - 100 for PWM function or 101 - 200 for servo control (1.01 to 2.00 ms Pulse) I added a accessible trim function for servo pulse finetuning. The State shows if the device is present and accessible. The IN shows the actual frequency register value.
Top |
Moderator3S
PostPosted: Thu Dec 31, 2015 7:40 am |
Offline |
Frequent User |
Author: PhilipLykov Date: 12.10. 2015 Version: 1.0.0.0
A library for UPS PIco for Raspberry Pi. Includes the following functions: - read voltage - read temperature - read analog inputs - read other parameters - control LEDs - control of cooler (including automatic control based on temperature) - Still Alive Timer (watchdog which will reboot the Raspberry Pi if your code will stop) - initial configuration of the device out of your code
Top |
Moderator3S
PostPosted: Fri Apr 29, 2016 4:39 am |
Offline |
Frequent User |
Author: galexis Date: Sun Apr 17, 2016 Version: 1.0.0.0
librarie for DS1803 i2C 2 potentiometer output
Top |
Moderator3S
PostPosted: Fri Jul 01, 2016 8:38 am |
Offline |
Frequent User |
Author: johan76swart Date: 17.06. 2016 Version: 1.0.0.0
MCP4725 digital to analog converter Input an integer 0-4095(12-bitDAC)
Top |
Moderator3S
PostPosted: Wed Nov 30, 2016 5:40 am |
Offline |
Frequent User |
Autor: galexis Date: 16.11. 2016 Version: 1.0.0.0
MCP3202: Rpi 1: pin1 > pin 24 pin5 > pin 19 pin6 > pin 21 pin7 > pin 23
Top |
