It is currently Sun Sep 23, 2018 2:04 am
 Post subject: OPC client with CODESYS
PostPosted: Wed Jul 09, 2014 4:21 pm
Is it possible to read data from a OPC server, with a CODESYS V2.3 PLC (Eaton XV panel)?
The OPC server uses the OPC XML DA protocol.
If that is not possible, what is a good solution to read this data?
Regards,
Henrie
PostPosted: Fri Jul 11, 2014 7:01 am
Hello Henrie
If OPC XML DA is supported or not -I don't know... Sorry!
But from WHERE are you going to read data from the PLC? Is there a management system a level higher?
Maybe the easier way is to write date from the PLC to anywhere..., e.g. into a database, file,....
Roger
PostPosted: Mon Jul 14, 2014 11:54 am
Hello Roger,
Thanks for the replay.
It is an existing system, were I need to modify some variables by the OPC connection.
I can not do anything on the existing system.
I was thinking the Eaton XV panel is running on Win CE 5.
Is there maybe a OPC client software for Wince5, where codesys the data read from?
Regards,
Henrie
PostPosted: Fri Oct 17, 2014 3:41 pm
yes contact codesys they do have this as a separate option.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
