It is currently Fri Jan 24, 2020 9:42 pm
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Wed Apr 02, 2014 12:41 pm
To the good people of the CODESYS forum,
I've been developing a system with the new release of the Raspberry Pi platform. What's great about the GPIO access is you can have various other devices running on a "C" program and if any of you are familiar with the WiringPi libraries (found here), then you can actually "pulse a GPIO" upon a program condition, this way the codesys application can then register a change and drive other sub-systems (say a WAGO connected on the Pi's Ethernet).
It's brilliant!
The final sub-system I need to connect is a current sensor through I2C. I have the INA219 board, bought from here).
I've attached my feeble attempt at writing the driver from scratch, basing it on the Adafruit_I2C_PWM library.
The software recognizes the I2C setup, but I don't believe it "properly" connects to the device let alone control it at the current state it's been written in.
If anyone can aid me in my struggle I would be immensely grateful.
-Hodgy.
_____________________________________________________________________________________________________________
INA219 Current Sensor Datasheet: http://www.adafruit.com/datasheets/ina219.pdf
PostPosted: Thu Apr 03, 2014 8:43 am
Hi Hodgy
Unfortunately we do not have the device here to test it.
But looking into your library, I can see that the default i²c address (that is used if you do not set the address in the device configuration (parameters)) is 0x41 (see body of Adafruit_CurrentSense, line 6). Did you verify this with i2cdetect?
What I saw in the Adafruit example code is that the registers are 16bit long:
  uint16_t config = INA219_CONFIG_BVOLTAGERANGE_32V |
                    INA219_CONFIG_GAIN_8_320MV |
                    INA219_CONFIG_BADCRES_12BIT |
                    INA219_CONFIG_SADCRES_12BIT_1S_532US |
                    INA219_CONFIG_MODE_SANDBVOLT_CONTINUOUS;
  wireWriteRegister(INA219_REG_CONFIG, config);
In your lib you used the write8 method.
Currently, there is no ready-to-use write16 method, but it is easy to program in your own lib:
METHOD write16 : BOOL
VAR_INPUT
      usiRegister: USINT; (* register to write *)
      uiValue: UINT; (* value *)
      Buffer:  ARRAY[0..2] OF BYTE;
Buffer[0] := usiRegister;
Buffer[1] := UINT_TO_USINT(SHR(uiValue, 8));
Buffer[2] := UINT_TO_USINT(uiValue AND 16#FF);
Write16 := DINT_TO_BOOL(Write(ADR(Buffer), 3));
I guess that this should solve the problem!
Instead of the BeforeWriteOutputs method you should use the AfterReadInputs method, as this device is an input device. You can compare to the SRF02, which is also a pure sensor which is similar to yours
"c:\Users\<Username>\CODESYS Control for Raspberry PI\1.1.0.0\I2C_SRF02.library"
PostPosted: Mon May 26, 2014 4:46 pm
How to install this
Quote:
Adafruit CurrentSense Library.library [339.17 KiB]
Adafruit CurrentSense.xml [2.51 KiB]
libraries into system to actualy get this device working ?
PostPosted: Mon May 26, 2014 5:50 pm
what exactly does not work, the install process to the repositories or adding the device and library and use them?
we need more information.
PostPosted: Mon May 26, 2014 9:56 pm
I'd like to know when I have .library and .xml how to install it into codesys. In this case I mean about those two libraries. I had download it from forum, but did0t know what to do with it :(.
PostPosted: Tue May 27, 2014 4:33 am
the procedure is:
install the library by Tools-> Install Library
this install the library to the library repository
install the device by Tools-> Install device
this install the device to the device repository
PostPosted: Tue May 27, 2014 8:41 am
Great! That's clear.
I'm starting to develop library based on PiFace. I'm not sure I'll succeed so easy, so how to deinstall device and library from system?
BR,
Mladen
PostPosted: Tue May 27, 2014 2:58 pm
important point is for library development you need to switch to professional mode
under Tools-Features. (see screenshot)
If you use CODESYS in "Standard" User mode you could not even save the library.
best practice for library development is:
Open two instances of CODESYS
one instance 1 of CODESYS -> open the library which you want to develop (open for example d:\I2C.library)
second instance 2 of CODESYS -> open th project which you could test your library. (open for example d:\Testproject.project)
(Also debugging in the project (this is instance 1) in the library is possible... by setting brakepoint in the library fb's)
If you change some implementation on Library use the yellow symbol to update the library in the library repository
the second instance of CODESYS recognize the change and you need to download the changes and could retest the new changes.
Last edited by Edwin Schwellinger on Wed May 28, 2014 3:24 pm, edited 2 times in total.
PostPosted: Wed May 28, 2014 11:07 am
Hi!
Idea about using two IDE for library development is great. Library and device should be installed first and import device/library into new project, am I right ? In this scenario then I have to open library from "C:\ProgramData\CODESYS\Managed Libraries\VendorName\...." ?
BR,
Mladen
PostPosted: Wed May 28, 2014 11:08 am
I presume to remove device and library from system is enough to delete folders e.g. "0000 0003" from "C:\ProgramData\CODESYS\Devices\501" and "Raspberry SPI PiFace" from C:\ProgramData\CODESYS\Managed Libraries\3S - Smart Software Solutions GmbH\" ?
PostPosted: Wed May 28, 2014 2:13 pm
>I presume to remove device and library from system is enough to delete folders e.g. "0000 0003" >from "C:\ProgramData\CODESYS\Devices\501" and "Raspberry SPI PiFace" from C:\ProgramData\CODESYS\Managed Libraries\3S >- Smart Software Solutions GmbH\" ?
Would not recommend to open them from the repository location, you need to copy them to d:\ (somewhere on your harddisk) open it from there
and install it later by CODESYS to the repositories (same for Devices).
BR Edwin
PostPosted: Wed May 28, 2014 2:29 pm
Edwin,
I asked about how to delete library and device :)
PostPosted: Wed May 28, 2014 2:36 pm
delete devices here:
and delete libraries here:
Altough I do not know why you want delete them...
PostPosted: Wed May 28, 2014 2:41 pm
Hmmm :?:
Please can you explain how to open same library in two IDE? First is developing and library is on temporaly folder, and second is testing IDE.
BR,
Mladen
PostPosted: Wed May 28, 2014 2:42 pm
When I make some seriuos error while developing new device/library :)
