It is currently Thu Oct 17, 2019 12:20 pm
 Post subject: how to add TextList
PostPosted: Fri Jul 06, 2012 12:13 pm
I tried to make a dynamic texts display
The online help said there need to have a TextList. The problem I met is there is no such options (" ⇘ Add Object' / Textlist") as the help described. I tried on both POUs and Devices window, without luck. Is anyone can give me a hint?
thank you very much
Jeff
 Post subject: Re: how to add TextList
PostPosted: Fri Jul 06, 2012 12:40 pm
Hi, Jeff,
First, I think you posted into the wrong area in this forum, this one is for scripting, so you will most likely get better answers when you post in the main CoDeSys V3 area. :-)
Second, in my CoDeSys, I can easily add Test Lists both under the application and in the POU view, as you can see in the 2 screenshots I attached.
HTH,
Markus
Users browsing this forum: Halim and 0 guests
