It is currently Sun Aug 18, 2019 7:06 pm
Post new topic  Reply to topic  [ 10 posts ]
 Post subject: TCP Socket example?
PostPosted: Thu May 04, 2006 10:45 am
Could someone nice post SysLibSockets library(SysLibSockets.lib) example?
Maybe TCP-server and TCP-client.. :roll:
 Post subject:
PostPosted: Thu May 04, 2006 12:24 pm
Ask at the 3S-support for the TcpUdplib.lib and for an example.
 Post subject: Example TcpUdp.pro
PostPosted: Thu May 04, 2006 12:26 pm
Hello
There's a very useful example project, TcpUdp.pro (enclosed). It includes a TCP Server and Client as well as a UDP Producer and Consumer. The functions within come from the library TcpUdpLib.lib and are modified a little bit.
Bye, Frank Hailer
Qualit├Ątssicherung
 Post subject: SysSockSelect
PostPosted: Mon May 08, 2006 7:47 am
Hi!
Thanks from example. I got my project working :)
PostPosted: Mon Jun 12, 2006 6:10 am
Actually I still have one problem. I can reveive messages from my client(LabView-prgoram) to my Codesys-server, but I can't send messages to Client. I get allways -1 value from Codesys SysSockSend-function. If I check last "TCP/IP API Error Code", I get error "235 Operation would block". Is there problem with socket options, or something else?
PostPosted: Wed Nov 12, 2008 11:11 am
Thanks for the TCPUDP example
 Post subject: Re: SysSockSelect
PostPosted: Wed Mar 14, 2012 11:34 am
Antti wrote:
Hi!
can u give me the TcpUdpLib.lib fast i am in need :|
 Post subject: Re: TCP Socket example?
PostPosted: Fri Jun 06, 2014 8:45 am
Looking for a "exemple.pro" to create a tcp server nonblocking
that proposed above is blocking "tcpudp.zip"
Thank you in advance for your help,
jlm
 Post subject: Re: Example TcpUdp.pro
PostPosted: Mon Jan 29, 2018 8:37 am
Frank Hailer wrote:
Hello
Bye, Frank Hailer
Hi, How can I open the example project "TcpUdp.pro" in CoDeSys V3.5?
Thank you very much.
PostPosted: Mon Jan 29, 2018 8:41 am
jlm60 wrote:
jlm
Hi, How can I open the example project "exemple.pro" in CoDeSys V3.5?
Thanks you very much!
