It is currently Tue Jan 21, 2020 1:00 am
PostPosted: Fri May 18, 2012 9:23 am
I have explored the CoDeSys API and help file. Also we have used Python introspection on the various interfaces/objects of projects, project, library manager to no avail.
I am trying to find API to upgrade/invoke the following:
1. Visualization Profile Version
2. Compiler version
3. Visualization Style Version
4. Build the Project
Any help would be much appreciated.
PostPosted: Fri May 18, 2012 9:32 am
Hi, lyn,
2. Compiler version
Currently, there's no ScriptEngine API available to set those versions.
You may use your support contact to raise this as an "Requirement" issue in our support database.
Building of the project is currently only implicitly triggered when a login to the device is done. Explicit access to the build commands is currently planned for V3.5 SP2 (Issue CDS-22407). You may use your support contact to add your company as an interested customer in this issue.
HTH,
Markus Schaber
PostPosted: Fri May 18, 2012 9:58 am
Hi Markus,
Thanks for quick reply.
when V3.5 SP2 is going to release ?
Thanks ,
Lyn
PostPosted: Fri May 18, 2012 10:04 am
Hi, Lyn,
We're just finishing the Release of V3.5 SP1 those days. V3.5 SP2 is currently planned for December 6th.
HTH,
Markus
PostPosted: Fri Feb 22, 2013 9:40 am
Hello Markus,
Do we have any update as to whether the Build Project API has been incorporated?
Thanks.
PostPosted: Fri Feb 22, 2013 9:52 am
The improvement was incorporated into V3.5 SP2:
Project objects were extended with the following members:
  • check_all_pool_objects() which works when the current project is a library project, and it resembles the "Check All Pool Objects" command from the "Build" menu.
  • generate_runtime_system_files(string destination_directory, bool generate_m4 = true, bool generate_c = false) to generate the C headers for native libraries.
  • clean_all() to perform a clean_all.
  • save_as_compiled_library(destination)
Object objects are now extended with the following members:
  • is_application - property getter which is true when the object is an application.
Objects which are Applications now extended with the following members:
  • is_active_application - property to chech whether this application is the active one.
  • build() - build the application.
  • clean() - clean the application.
  • generate_code() - Generates the code for the application.
  • rebuild() - rebuilds the application.
  • create_boot_application(string output_filename) - Creates the offline boot project at the specified outputpath.
Users can use the system.get_messages(Guid) and system3.get_message_objects(Guid, Severity) calls to check whether any errors or other compile messages were added.
To help the users to find the appropriate messages, system.get_message_categories() and system.get_message_category_description() were added, so they can print all message categories and their guids.
PostPosted: Tue Apr 09, 2013 1:07 pm
Thanks Markus. This is really useful info.
PostPosted: Tue Apr 30, 2013 2:02 pm
If you're still reading: Could you describe the exact use case?
Would the possibility to allow an upgrade of those elements to the newest version (in analogy to the "Project Environment" dialog) be enough? (This is already filed as an improvement in our jira database: CDS-34105
Or do you really need to explicitly set those versions to arbitrary values via scripting?
Thanks,
Markus
PostPosted: Fri May 03, 2013 11:44 am
Yes. The requirement is to upgrade to the newest compatible version via scripting. i.e. set the versions to the newest version/some specific version so that manual upgradation of the versions of tons of project is avoided and can be done easily via. scripting.
Best.
PostPosted: Fri May 03, 2013 12:29 pm
The aforementioned CDS-34105 improvement will allow to upgrade to the newest version during project load, but not to a specific version.
Is the possibility to set a specific version really important? And what is the use case?
Thanks, Markus
