I am trying to create a script where I can build different versions of my applications by toggling pragma variables declaration.
I understand that the only way to change the code at this point would be:
1. Export the gvl as XML
2. Modify the XML
3. Import back the modified XML
My problem is: how can I modify the XML? Ironpython has no implementation of pyexpat.py, so nothing like dom, minodom or etree will work. I could use some .net constructs, but trying to import CLR gives me an error "Access to module clr not permitted".
Why restrict access to CLR......?
Anonymous
2012-05-16
Hi, Francois,
francois hat geschrieben:
2. Modify the XML
As soon as IronPython has a working XML implementation, we intend to ship it with CoDeSys. So the "best" way is to contribute a working XML implementation to the IronPython project. This gives a lot of positive karma.
Since V3.5, the System.Xml assembly is available for IronPython scripts:
importSystemdoc=System.Xml.XmlDocument()
For older CoDeSys versions, the possible workarounds include: [list=] [*]You can execute external commands (including cPython scripts) to process the XML for you. [*]Use Pyro or some other remote call tools to call a cPython "server" processing your requests [*]Use the ctypes module to import some native library which does the processing. [*]Modify the XML using simple text manipulation (this works for some simple cases.) [/list]
For several (mostly political) reasons, the ScriptEngine is "sandboxed" a little bit. If there are convincing usecases for access to the clr module, we might remove or rework that restriction, or expose the required functionality in a different way. Note that Automation Platform plugins are free to lift this restriction when they instantiate Script Executors for their own purposes.
With the System.Xml assemblies, it means minidom can be used with the following manipulations:
1.Take the CPython expatbuilder.py and copy it to the xml/dom scripts folder
2. With a slight modification to FePy's pyexpat.py , rename it to expat.py and copy it to xml/parsers scripts folder
\#import clr
\#clr.AddReference("System.Xml")
This enables the standard python xml implmentations!
Regards,
Francois
Anonymous
2012-05-18
Hi, Francois,
\#import clr
This enables the standard python xml implementations!
This is great news, thanks!
I just tested it, and it seems to work. I'll try to get this into V3.5 SP2. (It is to late for 3.5 SP1, code close was more than 1 month ago...)
The last time when I checked pyexpat.py, it did not really work well - even using minidom did not work. (And I tested it in plain IronPython without CoDeSys.)
Anonymous
2012-07-02
Just another update: In our Jira-Database, we opened issue CDS-29369 to rework the sandboxing so "import clr" is allowed.
If you need "import clr" functionality, it is best to use your official support contact to get your company added to this jira entry.
HTH,
Markus
Anonymous
2012-10-24
Good news: the change which allows "import clr" did just slip into V3.5 SP2 (which is scheduled for december).
There are some filters in the AddReferenceXXX()-Calls which prohibit access to CODESYS internal APIs, but all other .NET Assemblies are freely accessible.
HTH,
Markus
As a solution to this I will show You script that I did create and it is used to module parameter changing. Basically it export module info to xml file, modify line with parameters and import this file again.
from__future__importprint_functionfromConfigParserimportSafeConfigParserimportos,ctypes,sysPATH=r"C:\\TestStand\\Systemtest\\Libs\\CoDeSys\\"BUS=='Profinet'COUPLER='Profinet_Coupler_Name'MODULE='Analog_Module_Name'IN_FILE=PATH+"export.xml"OUT_FILE=PATH+"import.xml"TCMASTER=PATH+"tcMaster.txt"Line=1
\# create the export reporterclassReporter(ExportReporter):  deferror(self,message):    system.write_message(Severity.Error,message)  defwarning(self,message):    system.write_message(Severity.Warning,message)  defresolve_conflict(self,obj):    returnConflictResolve.Copy  defnonexportable(self):    print("non exportable")  @property  defaborting(self):    returnFalse
\# create the exporter instance.exp_reporter=Reporter()Â Â Â Â
\# create the import reporterclassReporter(ImportReporter):  deferror(self,message):    system.write_message(Severity.Error,message)  defwarning(self,message):    system.write_message(Severity.Warning,message)  defresolve_conflict(self,obj):    returnConflictResolve.Copy  defadded(self,obj):    print("added: ",obj)  defreplaced(self,obj):    print("replaced: ",obj)  defskipped(self,obj):    print("skipped: ",obj)  @property  defaborting(self):    returnFalse
\# create the importer instance.imp_reporter=Reporter()defsubStrXml():  lRetVal=0  ifBUS=='Profinet':    PRETAG='<Element name="RecordData">'    POSTTAG='</Element>'  else:#'Profibus'    PRETAG='<Element name="userParameter">'    POSTTAG='</Element>'  IN_BLOCK=False  pos1=-42  pos2=-42  OUT="";  fhIn=open(IN_FILE,"r")  fhOut=open(OUT_FILE,"w")  TCM=SafeConfigParser()  TCM.read(TCMASTER)  print('Build: Text: Modifying file...')  # replace module parameters in xml file  forlineinfhIn:      pos1=line.find(PRETAG)# look for begin    pos2Offset=0    ifpos1>=0:      pos2Offset=pos1      pos2=line.find(POSTTAG,pos2Offset)# look for end, maybe same line    ifpos1>0:      IN_BLOCK=True      OUT+=line[0:pos1+len(PRETAG)]      try:        OUT+=TCM.get('DEFAULT',"Line"+INDEX).split(';')[int(SUBIDX)]      except:        print('Error: tcMaster - TC not found or index out of bound')        lRetVal=1            ifpos2>0andIN_BLOCK==True:      IN_BLOCK=False      OUT+=line[pos2:]    if(pos1<0orpos2<0)andnotIN_BLOCK:      OUT+=line    pos1=-42    pos2=-42  fhOut.write(OUT)  fhIn.close()  fhOut.close()  returnlRetValifBUS=='Profibus':  project=PATH+"Projekt\SysTS_FBC-PB-DP\\SysTS_FBC-PB-DP.project"  COUPLER='UR20_FBC_PB_DP'elifBUS=='Profinet':  project=PATH+"Projekt\SysTS_FBC-PN\\SysTS_FBC-PN.project"  COUPLER='UR20_FBC_PN_IRT_Profinet_Device'else:  print('Build: Error: Bus '+BUS+' not found')  flag=9  globData.write(globData.compile())  system.delay(3000)  system.exit()print('Build: Text: UUT Connection Type: '+BUS)
\# main program
\# export module to xmlobj=proj.find(MODULE,True)      if(len(obj)>0):  obj[0].export_xml(exp_reporter,IN_FILE,True)          # change module parameters  returnValue=subStrXml()        if(returnValue!=0):    print('Error')        else:    dev=proj.find(COUPLER,True)            # import module, move to correct position and run application    module_index=obj[0].index    obj[0].remove()    dev[0].import_xml(imp_reporter,OUT_FILE)    obj=proj.find(MODULE,True)    obj[0].move(dev[0],module_index)    os.remove(OUT_FILE)          else:  print('Build: Error: Object not found')
2. Modify the XML
Hi, Francois,
[list=]
[/list]
Thanks for your answer!
Regards,
Francois
Hi, Francois,
http://ironpython.codeplex.com/workitem/20023
HTH,
Markus
HTH,
Markus
And the tcMaster file kooks like this:
[DEFAULT]
Line1=[16#0A,16#00,16#04,16#01,16#0F,16#00,16#09,16#09,16#09,16#09]
Line2=[16#0A,16#00,16#04,16#01,16#0F,16#00,16#0A,16#0A,16#0A,16#0A]
It is easy to modify this to Your needs.
