Execute SMC3_ReinitDrive After Change Gear ratio of the Servo motor
drsumruay
2019-11-15
2019-11-29
  • drsumruay - 2019-11-15
    Hi, Everyone
    I found some problem with the SMC3_ReinitDrive Function Blocks. So when I execute this, It always keeps the state to busy.
    It doesn't seem to be done.
    Am I missing about this?
    Please guide me on how to fix it.
    With regards.
    IMG: Untitled.png
  • eschwellinger
    eschwellinger - 2019-11-16
    which drive is this?
    I think you need to check the logger, there you should see why the slave hangs on startup.
    (maybe could not switch ethercat op mode)
  • drsumruay - 2019-11-23
    Thanks, Edwin
    The log of the device doesn't show any info for this problem.
    The drive is Fuji Servo type: RYT101D5-VC2-Z88(EtherCAT)
    IMG: prob1.png
  • eschwellinger
    eschwellinger - 2019-11-27
    is this drive DS402 compliant?
    Then I would try to do it that way:
    l viewtopic.php?t=6254 l
    If you add the ESI file I would check if this might possible.
  • drsumruay - 2019-11-28
    The driver supports DSP402.
    I 've attached the XML file of the servo drive:
    if you need more information to solve this problem, please let me know
    With Regards
    IMG: Untitled.png
    RYT VC2 Z50_5000_0001.xml [90.14 KiB]
  • eschwellinger
    eschwellinger - 2019-11-29
    with attached ESI it looks that way:
    So my question is, where does it fail...
    you could set:
    SM3_BASIC_LOG_ACYCLIC_COM
    as compiler define ( righclick on the application and add this as compiler define)
    Then check the logger... in the situation it fails.
    IMG: Alpha5.png
