I have been tasked to develop a test engine that will be run on a completed product. This test engine will mimic commands that set, force, and read specific values in the PLC (Lenze). The functionally I need is available when the programming software is online with the PLC, within the 'Debug' menu.
Does anyone know if the communication protocol is published anywhere? I would really like to do this without having to reverse engineer the the communications with a packet sniffer.
tstevic hat geschrieben:
An other possibility would be to use Scripting to create your tests and run them through the CODESYS IDE.
Thank you for the answers. I attempted to install and try the Test Manager, however, it appears that Lenze version of the programming software does not coexist with Test Manager on the same computer. I will most definitely review the scripting option.
Hello Thomas,
you may want to take a look at the Test-Manager (https://store.codesys.com/codesys-test-manager.html), which should do the trick for you!
Best regards,
Marcel
Hi Thomas.
Look at the example "Reading of variable" at Scripts to Access CODESYS Functionalities. There is also an sub-forum where you can find examples and ask questions.
Martin
