runtime deploy tool hangs (3.5.14.300)
marks
2019-07-04
2019-07-19
  • marks - 2019-07-04
    I'm running Codesys V3.5 SP14 Patch 3 (64-bit), having upgraded from Patch 2 earlier while trying to diagnose this problem.
    When attempting to use the deploy tool from within the IDE, the seeming 'last thing done' seems to hang.
    For example, if I choose 'System Info' - it hangs while displaying 'Retrieving runtime system information", having quickly executed the previous cpu/network/package reads.
    If I choose 'Package install', it connects, downloads, and installs.. but the last message in the IDE, that it is installing, remains and the IDE hangs.
    If I restart the IDE and connect to the Pi, the runtime is installed and operating.
    Any ideas?
    Windows 10 64-bit system, up-to-date.
    I've tried uninstalling everything CoDeSys, rebooting, installing the 64-bit version, rebooting, downloading the Pi image (3.5.14.30), rebooting.. still hangs. 50+GB of available disk space, BitDefender turned off during the installs.
    Thank you,
    Mark
    Is there a logging feature within the IDE that would help figure out what is failing?
    Thanks,
    Mark
  • eschwellinger
    eschwellinger - 2019-07-05
    does a ssh connection work, for example use putty as ssh client with the same credentials you use in the
    Update tool?
  • marks - 2019-07-19
    Update tool?
    Yes, ssh (Putty) works fine.
