Hey,
I'm using CODESYS V3.5 SP14.
I created a WebVisu with some visualizations and downloaded it on the CODESYS Control Win V3.
When I try to access the homepage after starting the soft PLC I get the error message "cannot open document".
I already checked if the IP is correct and the name of the .htm file in the WebVisu settings.
I tryed to change the port (maybe there is another webserver running on the computer) in the CODESYSControl.cfg with
[CmpWebServer]
WebServerPortNr=9090
The PLC still starts the webserver with the default port.
Does anyone have an idea what the problem here is and how I can change the port?
Thank you for your help!
Fabian
