It is currently Wed Jun 26, 2019 12:50 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Wed Dec 19, 2018 12:07 pm
So, we have a SP14 available for few days. I Just installed It and I'm wondering how to use/where can I find this new ( updated ) version of Visualization? It looks really interesting and I was waiting for it long time:)
Thanks
Lukasz
PostPosted: Wed Dec 19, 2018 12:19 pm
Hello Lukas.
please check out the preparation steps here https://help.codesys.com/webapp/_visu_c ... n=3.5.14.0
However keep in mind this is a preview! Please report any issues found!
Best regards,
marcel
PostPosted: Fri Dec 21, 2018 6:55 am
think the missing part to enable it:
PostPosted: Fri Dec 21, 2018 12:41 pm
Do you plan to release Features And Improvements V3.5 SP14 brochure?
Make CODESYS great again
PostPosted: Wed Jan 09, 2019 10:49 am
Hi, friends.
Where I can find magic checkbox from Edwin screen?
PostPosted: Thu Jan 10, 2019 7:07 am
this checkbox does only apprear if only webvisu is attached to the VisuManager.
PostPosted: Thu Jan 10, 2019 10:20 am
Thanks!..
It was not obvious to me. I check help and I see that "presently no support in target visu", but I don't appreciated that it mean "you can't add target visu with this preview feature".
Also it will be fine to see small example with Animation Duration/Bring To Foreground paremeters.
Current description in help difficult to understand without examples.
It refers with this use case:
but I don't see new features, only common properties of elements (maybe because screenshots are missing?)
And in this arcticle:
https://www.codesys.com/news-events/pro ... -sp14.html
quote: "including easily configurable animations and usage of animated GIFs and SVGs"
Where information about how I can use Gif/Animated SVG with preview features?
PostPosted: Fri Feb 01, 2019 7:41 am
for animated svgs, simple use the normal image element.
However this currently only works for dynamic image elements (which are not optimized), so simple enter a FALSE into the invisible state.
Best regards,
Marcel
PostPosted: Thu Feb 07, 2019 8:10 am
Thanks, mr. Prestel.
Lifehack with invisible state := FALSE is awesome.
Maybe you can also explain me Animation Duration/Bring To Foreground properties with simple examples?
PostPosted: Mon Feb 11, 2019 8:02 am
Hey
do you mind telling me why the small example in the help is not sufficient enough?
Best regards,
Marcel
PostPosted: Mon Feb 11, 2019 11:26 am
I think you mean this example:
1. There is no screenshots (only missing links).
2. There is misprint: "Set the property value of Animation time " but in CODESYS IDE is written "Animation Duration"
3. There is no using Bring to foreground property in this example
4. I wonder why you can't give link to download this example instead of to suggest to create it from zero.
PostPosted: Mon Feb 11, 2019 12:51 pm
Hey,
thank you for your feedback.
I will get in touch with the documentation team.
Best regards,
Marcel
PostPosted: Mon Feb 11, 2019 4:48 pm
here is a small example for bring to foreground.
Best regards,
Marcel
PostPosted: Tue Feb 12, 2019 10:21 am
Thanks, m.prestel.
Your small example is much better than information from help.
Now I know that I can use variable for this properties (in IDE and Help: value, not variable. And there is no "..." button in IDE to link variable).
Also there is little difference in names: IDE - Bring to foreground, Help - Move to the foreground.
PostPosted: Tue Feb 12, 2019 11:39 am
We simple did not have the time for that.
Should be in SP15 however.
Best regards,
Marcel
