It is currently Sun Feb 23, 2020 12:49 am
PostPosted: Wed Jan 23, 2019 12:10 pm
Hello community
1º - I'm trying to test the Internet conection in my device. I got the idea of "doing a ping" to google, for example.
Apparently I can't do it directly, so i tried to open a socket in my application and use the function "SysSockPing" from SysSocket.lib. But always than a tried run it returns "1", in the CmpErrors it means "ERROR FAILED". For my surprise if i connect then send a mensage and then receive it actually works. What I'm doing wrong ?
2º- The time out of SysSockConnect is too long (1 minute approximately). Can i change it ?
  PROGRAM PingTest
VAR
 //// Create TCP socket ////
 diSocket : RTS_IEC_HANDLE;
 diAddressFamily : INT := SOCKET_AF_INET;
 diType : DINT := SOCKET_STREAM;
 diProtocol : DINT := SOCKET_IPPROTO_TCP;
 pResult: RTS_IEC_RESULT;
 //// Non-Blocking mode ////
 pResult6 : RTS_IEC_RESULT;
 diCommand : DINT;
 pdiParameter : POINTER TO DINT;
 //// Connect to server ////
  sockAddr : SOCKADDRESS;
  result: RTS_IEC_RESULT;
  pResult3: SYSSOCKET.RTS_IEC_RESULT;
  //pInAddr: INT;
 //sockAddr.sin_family := SOCKET_AF_INET;
// sockAddr.sin_addr := SysSockInetAddr('192.168.4.102');
 //sockAddr.sin_port := SysSockHtons(19998);
 //// PING /////
   PingTime: UDINT;
   pResult2: RTS_IEC_RESULT;
 //// SEND  /////
   send: DINT;
   hSocket : RTS_IEC_HANDLE;
   pResult4: RTS_IEC_RESULT;
   pbyBuffer: POINTER TO BYTE;
   diBufferSize: INT;
   diFlags: INT;
   Str : BYTE :=66; //caractere ASCII em DEC
///// REC /////
   rec : DINT;
   Str2 : BYTE;
   pResult5 : RTS_IEC_RESULT;
//// TESTE ////
   state : BOOL := FALSE;
   state2 : BOOL := FALSE;
   checkfail : INT;
   cont: INT;
END_VAR
 cont := 0;
 checkfail := 0;
 GVL.ResetCode := 1;
 //Create TCP socket
diSocket := SysSockCreate(diAddressFamily, diType, diProtocol, ADR(pResult));
//Non-Blocking mode
pResult5 := SysSockIoctl( hSocket := diSocket, diCommand := SOCKET_FIONBIO, ADR(pdiParameter));
//Connect to server
pResult3 := SysSockInetAddr('192.168.3.73', ADR(sockAddr.sin_addr));
sockAddr.sin_port := SysSockHtons(1234);
result := SysSockConnect(diSocket, ADR(sockAddr), SIZEOF(sockAddr));
WHILE (cont < 10) DO
IF (result =0) THEN
//Ping server
 pResult2 := SysSockPing(szIPAddress:='192.168.3.78', ulTimeout:=500,  ADR(PingTime));
// Send Byte
 send := SysSockSend(hSocket := diSocket , pbyBuffer :=ADR(Str), diBufferSize := 1, diFlags:=0 , ADR(pResult4));
// Rec Byte
 rec := SysSockRecv(hSocket := diSocket, pbyBuffer:= ADR(Str2), diBufferSize := 1, diFlags :=0, ADR(pResult5));
END_IF
//TesteSend = Rec
IF (Str2 = Str) THEN
   Str2 := 0;
   state := TRUE;
   checkfail := 0;
ELSE
   state := FALSE;
   checkfail := (checkfail + 1);
END_IF
cont := (cont + 1);
END_WHILE
 //Close connection
   SysSockClose(diSocket);
IF (checkfail >= 5)THEN
   state2 := TRUE; //teste conexão após os 10 ciclos, sendo true = conexão fail
   GVL.ResetCode := 0;
   ELSE
   GVL.ResetCode := 1;
   state2 := FALSE;
   END_IF
PostPosted: Thu Jan 24, 2019 2:07 pm
Had to issue a ping for an app, using festo hardware running codesys v3.5 SP10
This is my working code :
Global Vars
VAR_GLOBAL
// Diagnostic of TCP link
PingOk : BOOL;
END_VAR
Global constants
{attribute 'qualified_only'}
VAR_GLOBAL CONSTANT
   _IPSTRING: STRING := '192.168.1.1'; // IP to ping
END_VAR
Program
VAR
   PingTime: UDINT;
END_VAR
// Ping command
IF CmpErrors.Errors.ERR_OK = SysSockPing(szIPAddress:=Const._IPSTRING, ulTimeout:=500, pulReplyTime:= ADR(PingTime)) THEN
   PingOk := TRUE;
ELSE
   PingOk := FALSE;
END_IF
PostPosted: Fri Jan 25, 2019 1:08 pm
Global Vars
VAR_GLOBAL
PingOk : BOOL;
END_VAR
Global constants
VAR_GLOBAL CONSTANT
END_VAR
Program
VAR
   PingTime: UDINT;
END_VAR
// Ping command
   PingOk := TRUE;
ELSE
   PingOk := FALSE;
END_IF
I tried the same code and it continues returning cmperror =1 :?
PostPosted: Tue Jan 29, 2019 9:33 am
Did you tryied pinging a local IP address (on the same subnet) ?
Please check your gateway settings. If it is ok, and your Gateway can reach internet, you should be able to ping 8.8.8.8 (google dns server)
