It is currently Sat Dec 14, 2019 5:45 am
 Post subject: Fuzzy Logic C++ to ST
PostPosted: Mon Jan 21, 2019 7:12 pm
Hi All;
I have been translating the (open source) eFFL Fuzzy Logic library https://github.com/zerokol/eFLL from C++ to ST. I have attached a section of that translated work. Part of the reason for doing this is to reacquaint myself with the ST language.
The persistent problem is that, while the code compiles without errors or warnings, the simulator balks at a download with error: "C0367 Internal error 3 prohibiting online change! Clean application and download necessary". Cleaning the application makes no difference. I have been unable to track down the cause of the error and was hoping to find some help from someone who might have a better grasp of OOP principals as applied to CODESYS. There is a possibility of a call to an un-instantiated object, but i haven't found where.
An additional question i have is about the CODESYS "NULL" definition. The code compiles with NULLs, but the editor doesn't appear to recognize it as a defined symbol. I have tried replacing all the NULLs with a numeric '0' - this also compiles without errors, but made no difference to the download.
Any clues to getting this running would be appreciated.
Thanks,
Jeff
EDIT 1: Changed attached file to .project
EDIT 2: Corrected .project file attached
PostPosted: Tue Jan 22, 2019 11:14 pm
a null is not equal to a zero, null is nothing mostly 00 hex and a null is a symbol
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Wed Jan 23, 2019 7:08 am
you need to attach the .project file not the opt files…!
PostPosted: Wed Jan 23, 2019 12:47 pm
Thanks Edwin.
Find attached .project file in the edited post above
PostPosted: Tue Jan 29, 2019 5:44 pm
It took a bit of head scratching, but the solution presented itself eventually.
In a few cases, I was creating new objects like this:
IF ((aux := __NEW(fuzzySetArray)) = 0) THEN
// do something
END_IF
If the object creation is taken out of the IF statement, like this:
aux := __NEW(fuzzySetArray);
IF (aux = 0) THEN
// do something
END_IF
...then the download fault disappears and the simulator is ready to run.
Find the corrected (..._A.project) file attached to the first post above.
Jeff
